help with swap
my friends and i are putting a 95 gsr motor into a 94 civic dx coupe. we are having problems mounting it up. the rear mounting bracket that we have isn't long enough to reach the rear mount. all the other mounts are in place. the rear mounting bracket is supposed to be a gsr bracket. it fits on the tranny fine. what are the corrects mounts that we are supposed to use? any and all info, suggestions, and ideas are welcome. thanks!
Driver's Side mount bracket and mount - 94-01 Integra
Top Tranny mount - Stock Civic
Rear Upper Tranny bracket - 94-01 Integra with stock Civic rubber mount
Front Lower Tranny mount - 94-01 Integra bracket with stock Civic rubber mount
A/C bracket - 94-01 Integra with stock Civic rubber mount if you're only using it as a mount, 93-95 Del Sol if you want to keep the A/C
blueintegra90
Jun 11, 2004 04:03 PM
