HELP! Head swap problems
Ok my car is a 98 integra with an 95 jdm h22a. I recently swapped a type s head onto the car, but im throwing a code 3. I can't seem to find a vaccuum schematic for the car to tell if i hooked up the vaccuum lines wrong...would this cause me to throw a code 3? Any help/schematics would be greatly apreciated! Thanks guys
Are you getting any other codes? Reason I ask is because when I started my h22 up, I ran a code 3,12,36,41. After I hooked the vac lines up correctly, and reset the ecu, I only had the code 12(egr) which is no biggie. Try and reset the ecu and make sure all vac lines are hooked up correctly. Your map sensor still might be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">Isn't the map sensor screwed to the throttle body with no vacum line?</TD></TR></TABLE>
Thats correct.
Thats correct.
I think this is what your looking for. Its on the first page.
https://honda-tech.com/zerothread?id=650329
