Help with code 4
Old Jul 22, 2005 | 11:59 AM
alexb16hb's Avatar
Default Help with code 4
we are putting a jdm b16a (obd 0) into a 90 civic std. The motor is in and the car will start but we have a code 4 and the engine is runnig very poorly. Wondering if any one can help us rid the code.
Old Jul 22, 2005 | 04:23 PM
Slavko's Avatar
Default Re: Help with code 4 (alexb16hb)
Code 4 is the crank position sensor.
Old Jul 22, 2005 | 04:51 PM
alexb16hb's Avatar
Default Re: Help with code 4 (Slavko)
yea i know what code 4 is, just wondering if anyone has had this problem before and what they did to fix it!!!
Old Jul 22, 2005 | 04:55 PM
Slavko's Avatar
check your wiring around the distributor and check the timing of the distrubitor. Loosen the bolts that hold the distributor in place and have somebody rev the motor while you are turningt he distributor clockwise and counterclockwise until it sounds like its running good.
Old Jul 22, 2005 | 05:15 PM
alexb16hb's Avatar
we checked every wire from origin to the ecu and they all go the the correct pin. Thanks Slavko we will try dist. timing but i truly dont think that is it. Any body else with some ideas
ADAMnQuickRDX
May 7, 2009 11:30 AM
pokmijn
Jan 4, 2008 12:43 PM
GuyInASpeedo
Sep 25, 2003 07:05 PM
Spade
Jul 30, 2002 02:05 PM
wuhungsixxx
Oct 24, 2001 10:20 AM
