HELP- b18 wiring question
Old Nov 30, 2007 | 11:42 AM
greg@millennium's Avatar
Default HELP- b18 wiring question
doing a b18c1 swap into a 2000 civic w/ a obd1 ecu. have most of it fiqured out, but still have a few wiring questions.
1- the b18 engine has a placement for a crank angle sensor, but misssing. will i need that or not?
2- the blue wire coming out of the b18 distributor, where does that go????
3- there is a map sensor on the b18, but there was not on the d16. what do i do for that.
thanks in advance for any & all help
greg
Old Nov 30, 2007 | 06:16 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: HELP- b18 wiring question (greg@millennium)
CKF not needed if staying obd1. blue wire is a tach lead, idont think it is used, but not certain, and there has to be a map on your d16. keep looking.
Old Dec 3, 2007 | 10:46 AM
IIXtremeHansen's Avatar
Default Re: HELP- b18 wiring question (boostedcivicsir)
you map sensor is on your intake mani close to the throttle body.
Old Dec 3, 2007 | 07:57 PM
ltrkstr2k's Avatar
yeah the blue wire has to be wired in or else the car won't start. what engine harness are you useing . there should be a blue wire with the rest of the dizzy wiring next to a black/yellow wire
B Dap
Aug 13, 2010 09:34 AM
slkleltlclh
Nov 7, 2007 04:18 PM
2fast4udude
May 15, 2006 09:56 PM
spintegra91
Apr 5, 2005 07:50 PM
skierGT
May 16, 2003 09:42 PM
