hasport egh2
Old Dec 13, 2008 | 04:49 PM
makeustruggle's Avatar
Default hasport egh2
ok i done a h22a swap and using hasport egh2 mounts ,
i took it out today being that i finished everything and when
i punch the gas hard , the car starts vibrating/jumping hard..
i had some custom axles made , everything fits good but my
passenger axle touches the arm that holds up my coilover.
can someone who is running this mount kit wit a hatchback
tell me what axle to use exactly and length too.
Old Dec 13, 2008 | 09:20 PM
NAEGH22's Avatar
see here for axle information - https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/
also it sounds like your axle is touching your damper fork. check that you have the axle installed all the way in on the gearbox side.
as for your vibration, did you notch/hammer in or modify the frame rail at all under the tranny mount. cause if you didn't you may want to check for any signs of whether your gearbox is touching the frame rail or not because this has been a common cause of vibration problems with this swap using the EGH2 mounts.
hope that helps
mickey30
Transmission & Drivetrain
Apr 21, 2013 02:37 PM
flatblack-h22
Apr 12, 2013 06:11 AM
builthatch
Feb 26, 2008 11:30 PM
G-COM
Aug 9, 2007 02:37 PM
ScottEK
Aug 23, 2006 04:58 AM
