has anyone done this???
i have been reading up on sum d16 stuff and i found a guy using a d16y8 crank block and head with b16 rods and 1g-gte pistons he said with a thick head gasked he has around 8.5:1 compression and it holds strong to 20psi. i was interested and just want to know if anyone has done it or knows anything about it.
Modified by uglyef at 9:44 PM 7/2/2008
Modified by uglyef at 3:02 AM 7/3/2008
The single cam guys found a better alternative which is using hypereutectic Suzuki Vitra pistons made by YCP. Better because of the piston availability, fits onto stock rods/aftermarket rods, price, and is proven. Also the compression ratio is in the 8-9:1.
thats probly what i will end up doing but if i go the other way then the b16 rods are stronger then the d16 ones but if i cant find someone who has done it to ask q's then i will probly just go eagle H beams and the vitara's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDemoN »</TD></TR><TR><TD CLASS="quote">Just buy some eagle rods and be done with it.</TD></TR></TABLE>
Just make sure to get the I beam rods and not H beam rods otherwise you will be grinding your block so that they can rotate around.
sporkcrx
Aug 12, 2004 10:12 PM
