h2b probs
2 problems i need help with
1. ive instaled my h2b kit and built the engine back up, the starter motor bolt will only go in one, i never got and instructions with the qsd kit and ive only just dl the manual, but i did read loads of build ups on it and none of them said anything about it.
i dont want to take every thing off so could i just tape some threads into the hole on the gearbox and bolt the starter on ?
2. as said every thing is bolted on , my clutch slave cylinder is fitted but its pushed all the way in so the folk on the gearbox is all the way to the right. is this normal ?
what he said......if you don't want to pull the trans off you can always use a tap and throw the bolt in from the outside.....personally I would just pull the trans and put the bolt in (sticking out) properly with the head in the recess in the plate.
exxybihon
Aug 28, 2008 09:41 PM
