h2b idle problem need help ASA!!!
Old Aug 20, 2013 | 06:15 AM
aLlm0t0rboY's Avatar
Default h2b idle problem need help ASA!!!
hey honda tech... i need help i have a h2b,
h23a blue top vtech
b16 lsd tranny
skunk 2 intake manifold
plm 4-1 headers stock throttle body.
after i put the swap together the car has been idling up n down idk what could be the problem.. when the i bought the skunk 2 intake mani the icv was block off. idk if that could be the problem or the tps sensor.
my boy with a h2b said its a vacume leak. could that be? thank you
Old Aug 22, 2013 | 08:55 PM
jsinher3's Avatar
Default Re: h2b idle problem need help ASA!!!
what kind of ecu are u running, did you run or block off the coolant/heater lines to the TB, and IAC?
Old Aug 23, 2013 | 09:21 PM
f@sth@tch89's Avatar
based on the symptoms you listed I had a similar issue with my b16. I had the wrong TPS sensor on. Also I had to flip my TB gasket so the map could get more air. Problem solved.
Old Aug 26, 2013 | 05:07 PM
It's my old ecu from my b16 but a basemap for my h22 idk where the hoses for the iacv goes.. I bought a new one bc I didn't have one it was just blocked off..
Henson112233
Mar 30, 2013 05:17 AM
davenport517
13
Apr 21, 2008 11:27 AM
asianrepnsb
12
Mar 8, 2008 12:26 PM
MIZIKETSK
Sep 24, 2004 03:31 PM
HaUTSaauce
Mar 30, 2003 04:12 PM
