H2B / F2B FAQ
I bent up some welding wire as a template and went down to the local NAPA to find a hose with the right bends. Make sure you measure OD of the radiator and the water inlet on the head as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">I bent up some welding wire as a template and went down to the local NAPA to find a hose with the right bends. Make sure you measure OD of the radiator and the water inlet on the head as well. </TD></TR></TABLE>
You forgot to write down that part number didnt you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">You Liar </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel »</TD></TR><TR><TD CLASS="quote">
You forgot to write down that part number didnt you? </TD></TR></TABLE>
yep, I have been asked this questions several times too.
yep, I have been asked this questions several times too.</TD></TR></TABLE>
well dang you. I think eventually Im just going to have some hoses made and some fittings just welded in the spouts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Anyone try to run a/c on an ek with h2b?</TD></TR></TABLE>
It could be done but you would have to modify the frame rail and/or headlight support thinger mabobber and have custom ac lines. It can be done, just gotta get creative.
So after talkin with bense earlier I guess the 97 version is a odd-ball. It comes with 50mm mains not 55. The crank snout is smaller. Im gonna try and measure as much as I can tonight and give you guys some specs
Few have questioned the possiblity of AC & Power Steering with the H2B concept. Hopefully this post will help sum up a little bit about what is involved.
Take a look at this pic...
A little bit a banging is required to run the alternator in the OEM position. The framerail was cut for clearance in this pic... an effective solution other than the "bang, test, bang bang some more, test, good" procedure.
The power steering belt travels on the outside of the alternator pulley. Do you see any room to run it in this pic? No. So you have two options, don't run it at all or modify your frame rail to do so.
I have seen H22 Hybrid configurations with AC where the belt powering the alternator is also powering the AC compressor (serpentine) inconjuction with a tensioner. I cannot recall if the bracketry mounting the compressor was OEM or afterrmarket (HCP?).
Again you can see from the above pic that the clearance is tight. Using the serpentine method mentioned above with possibly the use of a few custom/mix match components, it is feasable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">So there's hope, so how would I get the serpentine to run? With a special tensioner?</TD></TR></TABLE>
You see, that's not an 'H2B' thing. That is a H22 'Hybrid' question, and I am sure if you looked through one of the "H22 Air Condition" thread the answers will be found.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">Thanks for the help Seth
x2
</TD></TR></TABLE>x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 »</TD></TR><TR><TD CLASS="quote">^^ thats tight!!! but hows the alt mounted to compensate for engine movement?
the bracket will have some of what the motor mounts are made out of,so it will give just a hair.with the hasport race mounts in.i don't think she is going to move very much at all....but we shall see.i just cain't get over how trick it looks.....i'm loving it.
</TD></TR></TABLE>the bracket will have some of what the motor mounts are made out of,so it will give just a hair.with the hasport race mounts in.i don't think she is going to move very much at all....but we shall see.i just cain't get over how trick it looks.....i'm loving it.
