H2b in a eg
Ive Searched but i cant find.. i have a 93 dx bubble and im putting a h2b motor in it ... im using the evolutions h2b kit...i know i have 2 get and i already have the h motor, b16 trans, act clutch, avid shiftlinkage, gsr half shaft and axles, p28 ecu,i got custom headers and i got the alternator bracket ..
im only stuck on the rear l bracket do i need one with the h2b setup common sense tells me yes but which one do i use and since my cars a dx would it be a good idea 2 buy a 0bd1 ex/si engine harness.. and would it matter if i get for example a ex automatic engine harness.. thnk u and help would be great
are you gonna keep your balance shafts or not? check out this thread https://honda-tech.com/zerothread/1998426
the rear L bracket should be from a 94+ integra or 99-00si
Use your stock harness and add the few extra sensors
It's gonna be a bigger headache if you are running the egr system. check out the h22 thread stickied at the top for all the h22 wiring info
NewCarScent
Oct 1, 2017 03:55 PM
Boostless97Lude
Nov 21, 2002 09:19 AM
