H2B In A DB2?
Old Aug 21, 2008 | 06:56 AM
The G2 Racer's Avatar
Default H2B In A DB2?
Need some help in figuring out all the parts I need for this.
Obviously I need the H2B adapter kit, OSD or Bisi?
I plan to ditch my power steering (looping the PS rack) and A/C. Also going to run a half core rad.
Car is a 93 DB2 with a B16 in it. I want to know what parts I'll need apart from the adpater, clutch/flywheel, poly mounts, etc.
I did search and didn't turn up too much.
Old Aug 21, 2008 | 07:28 AM
LA_HONDAS's Avatar
Default Re: H2B In A DB2? (The G2 Racer)
remove the bs http://kaizenspeed.com/detail....0&NM=
use a b-series flywheel/clutch starter linkage axles halfshaft
ill go with the qsd kit cuz its cheaper and cuz you use b-series mounts with it http://quartersportsdrag.com/FAQ.html
and you need the upper alt kit http://explicitspeedperformance.net/H22Aalt.html
and go to the h2b faqs
Old Aug 21, 2008 | 07:42 AM
LA_HONDAS's Avatar
Default Re: H2B In A DB2? (LA_HONDAS)
you gonna need to do your crank pulley
and you need a h2b header or mod your stock h22 header
Modified by LA_HONDAS at 3:27 PM 8/22/2008
Old Aug 21, 2008 | 07:22 PM
DB2 is a 92-93 GS-R.
Thanks for the help.
Old Aug 21, 2008 | 07:51 PM
gibsanez's Avatar
Your engine will more than likely stick through the hood.
Old Aug 22, 2008 | 05:12 AM
Default Re: H2B In A DB2? (gibsanez)
I read a thread about how one guy got around that.
Involves cutting the engine bracket.
I might cut out the inner hood skelton and space it a bit, we'll see.
EDIT: What about wiring?
Modified by The G2 Racer at 2:26 PM 8/22/2008
Old Aug 22, 2008 | 05:54 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G2 Racer &raquo;</TD></TR><TR><TD CLASS="quote">I read a thread about how one guy got around that.
The wiring will be the same as a straight H22 swap. The car is already OBD1 and wired for VTEC.
If you space your engine down you'll end up taking up the already minimal ground clearance for the exhaust and oil pan. The easiest method will be to make some sort of cover for the hole, whether it be a bump or an entire raised section of the hood.
Old Aug 22, 2008 | 06:21 AM
LA_HONDAS's Avatar
take you stock harness and make the alt wires longer
Old Aug 22, 2008 | 11:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">
If you space your engine down you'll end up taking up the already minimal ground clearance for the exhaust and oil pan. The easiest method will be to make some sort of cover for the hole, whether it be a bump or an entire raised section of the hood.</TD></TR></TABLE>
How bad will it be though?
With the tools are my disposal I could easier fab a nice skid plate for the motor and what not.
Old Aug 22, 2008 | 12:23 PM
LA_HONDAS's Avatar
gc is about 3.5" to 4.5" from the bottom of the oil pan with the qsd kit
how much did you lower car
and if you got good streets where you at you dont need a skid plate
Note new york is bad with car killing pot hoses
Old Aug 22, 2008 | 12:42 PM
Toronto has just as shitty streets as NY I bet.
My car is pretty dumped, I'll have to figure out what to make the skid from.
Old Aug 22, 2008 | 12:48 PM
LA_HONDAS's Avatar
3/16" or 1/4" steel plate
Old Aug 22, 2008 | 01:13 PM
Steel will be too heavy, need to figure out something strong and light weight.
Aluminum might work if it's fairly thick.
Old Aug 22, 2008 | 01:22 PM
LA_HONDAS's Avatar
if you use aluminum ill go with 1/2"
just a note i price some aluminum 25"x25" 1/2" thick and was $400
so if i was you ill go with steel
Old Aug 22, 2008 | 01:52 PM
I'm aware of the cost. Fabbed more then enough stuff for my Jeep.
I wish steel was cheap like a few years ago.
Old Sep 6, 2008 | 10:20 AM
Gen2ITR's Avatar
I completed my H2B swap in my DA (1990 LS integra) in January.... Its alot easier then I think people are trying to make it.... I did go a different route then suggested tho...
I used the full Evolution/Bisimoto kit (minus the mounts). Having used the other kit in a customers DC, I personally prefer the quality of the EVO/Bisi kit.
I made 1 (one) custom drivers side engine bracket. This allowed me to use the full HASPORT DA mount kit.
I removed the IAB butterfly plate, cut the skeleton out of the hood (which was already done) and made about 1" spacers for the hood mounting.
EVERYTHING else used in the swap was off the shelf parts or modified factory parts.
I have been daily driving this car since late January. I was even told at the Eibach Show that this swap couldnt be done without ALOT of other issuses (ie: the maifold hitting the firewall or sticking through the hood 6 inches....
I'll be happy to answer any questions you might have, just PM me!
Old Sep 6, 2008 | 10:31 AM
Gen2ITR's Avatar
Ive got alot of other little secrets for the DA Chassis too!!! Hit me up!
Old Sep 7, 2008 | 09:04 AM
donkeykongvtec's Avatar
Mad props on the H2B in a DA; What is your best ET in the H2B DA?
Old Sep 7, 2008 | 10:37 AM
projectTeG's Avatar
contact quarter sports. their H2b was built in their db2.
Old Sep 17, 2008 | 03:52 PM
NABeastRR's Avatar
Default Re: (projectTeG)
im making a custom valve cover that gets rid of a good inch. remove the iab plate also ...custom cover is coastin me guy said 150 to 200 i look at it theres tons of peps out there who buy 150ish red & blue oem covers soo whats a lil more & save a inch in spacing & my car is a ef.
Old Sep 22, 2008 | 08:51 PM
Gen2ITR's Avatar
Default Re: (donkeykongvtec)
Between tuning issues and Axle snapage, I only got one clean run in....
I ran a 13.84 @ 10? (dont have the timeslip nearby)
It was a high 1.8ish 60ft
I babied the launch and shifts to avoid more axle problems...
I think with a better tune and stronger axles I can pull low 13's to high 12's.
Old Sep 24, 2008 | 10:47 AM
Default Re: (Gen2ITR)
Gen2ITR, I want to see some pictures with your hood closed.
The only thing really stopping me from doing this is the fact that I will have to space out my hood. Personally think it looks ugly (car is a mix of performance and looks).
Old Sep 27, 2008 | 02:10 AM
Gen2ITR's Avatar
Default Re: (The G2 Racer)
Ive gotta put the car down during the day tomorrow...I'll take some pics then!
Old Oct 1, 2008 | 05:35 PM
Gen2ITR's Avatar
Old Dec 25, 2008 | 01:17 PM
Bumping this back up again for any more opinions.
I really want to have my hood sit flush.
