h22swap
Old Jun 2, 2002 | 03:08 PM
transmission11's Avatar
Default h22swap
my friend says that if you drop a h22 into a civic that it leans the wrong way and messes up the frame. is this true?
Old Jun 2, 2002 | 03:16 PM
631 Teggy's Avatar
Default Re: h22swap (transmission11)
Don't question me bitch
http://www.vtectuning.com/info.html
Scroll down to where it says H22A
Old Jun 2, 2002 | 03:20 PM
Default Re: h22swap (631 Teggy)
haha fagget
Old Jun 2, 2002 | 03:26 PM
Kamin's Avatar
mess up the frame no, but yes it does lean the wrong way and will give you understeer problems.
Old Jun 2, 2002 | 05:07 PM
showstopper's Avatar
Default Re: h22swap (KAMiN)
I have an H22 swap in my Integra, and it runs good.
Old Jun 4, 2002 | 05:54 PM
Default Re: h22swap (showstopper)
how much did it cost for you to put it in? Or did you do it yourself
Old Jun 4, 2002 | 11:15 PM
 mycro_machine's Avatar
hey what kinda suspension did u use for the swap. thanks bro
Old Jun 5, 2002 | 01:08 AM
Newman's Avatar
New User
Yes it leans the otherway, but it makes steering so much easier (center of gravity of the motor is more towards the center of the car... with a B-series motor, it tilts forward, thus putting more weight in the front --- PS with a H22 motor in a Civic is for wussies IMO... it's not needed)
As for it understeering a lot... a huge myth. People need to go out and drive a H22 Civic for themselves before they say this or that about what their HEARD. Go here: https://honda-tech.com/zerothread?id=183552
Perfect example of how a H22 Civic handles on a sanctioned Road Race course.
BTW, here's an old pict:
Ran a best of 12.6 @ 119mph on slicks... all motor, stock motor. 100 shot of NOS is added... time to go time it again....
Old Jun 5, 2002 | 02:59 AM
97hb's Avatar
Default Re: h22swap (Newman)
I like your mph, its up there
Old Jun 5, 2002 | 07:26 AM
Jason kiDD's Avatar
Default Re: h22swap (97hb)
Also if you looked at a stock H22 engine in a lude, it has a tilt backwards as well which is what I noticed while using the HCP mountkit.. So its similar to its stock position..
Old Jun 5, 2002 | 09:29 AM
Mikey3000's Avatar
why do people give out false information? information which they haven't experienced 1st hand. those people are dumb as dirt. vtectuning? who the **** are they? i live in no. va and haven't heard of them. my h22 doesn't lean back towards the firewall. and even if it did, i'd think that would be better for handling. h22/civic's (if done right) do not handle like ****. they handle just fine for everyday driving. there isn't as much "fabrication" as they say there is either. one stock mount needs to be taken out in some cases and that's it. there's your major fabrication. VTECTUNING SUCKS! get information from people with experience and not hearsay.
Old Jun 5, 2002 | 12:36 PM
Default Re: h22swap (Boss Hogg)
how much did it cost to put your engine in? You have to get rid of the old civic engine mounts and buy new ones for the lude engine right? -Thanx man I think i may have made a decision to go for the swap..now its time for saveing
Old Jun 5, 2002 | 12:47 PM
Jason kiDD's Avatar
Do you have any pictures of your interior?? I used my Accord shift lever and it doesnt seem like the Civic center console is going to fit over it. I just wanted to see what other people were using..
Old Jun 5, 2002 | 12:57 PM
boosted1993fd's Avatar
Its not a civic...but same platform.....
and handling is great in my integra.....after adding a type r sway bar and a few other suspension parts...my handling is way better than it was stock...even with the h22's added weight up front...
Old Jun 5, 2002 | 01:41 PM
631 Teggy's Avatar
Yo chill man... I've seen a 50-50 say here... Some people say it's not ideal... And every hybrid site I've seen says it's not sugested... Seriously dude, calm down! I was trying to warn the kid... So once again... Chill...
Old Jun 5, 2002 | 01:51 PM
Newman's Avatar
New User
You use a mount kit, which replaces all of your stock mounts. Only the HCP mount kit (which I use and sell) does not require any cutting/welding in the engine bay. Therefore, if I really wanted to, I can throw a B-series motor back into my car and it'll bolt right in.
As for installation, very easy and quick. Believe it or not, it's faster to bolt in a H22 motor than a B-series motor (took us 12 minutes to get it all bolted up.... the easy way is to have the motor on the ground, drop the chassis ontop of it, bolt the rear mount first, then sides and you're set).
Old Jun 5, 2002 | 02:58 PM
nice
Old Jun 5, 2002 | 03:04 PM
MrSmith's Avatar
does hcp make a mounting kit for 6G civics as well? Or can the 5G kit be adapted to fit?
Old Jun 5, 2002 | 04:06 PM
Jason kiDD's Avatar
Default Re: h22swap (MrSmith)
I should be a salesman...
Check out http://www.jdmshit.com
What do you think Newman??
Old Jun 5, 2002 | 09:09 PM
Newman's Avatar
New User
Default Re: h22swap (Jason kiDD)
Hehe....
Old Aug 15, 2003 | 07:00 PM
leatherneck28's Avatar
Default Re: h22 swap questions?/
do u know where i can get a step by step install for a vtec h22 into a 91 si hatch?
Old Aug 15, 2003 | 09:44 PM
nickwilmot's Avatar
To swap a the motor by droping the chasis on top of it, doesn't it invole removing the frot suspension? How hard is it to do it from the top
Thanks
Old Aug 15, 2003 | 09:51 PM
hondaeg5's Avatar
[/QUOTE]
maybee im wrong, but in almost every picture of a h22/hcp mount kit installed i see that they have cut the passenger side trans mount??
Old Aug 15, 2003 | 10:29 PM
BUBZC1's Avatar
Default Re: h22swap (hondaeg5)
I found my donor h22a from a rolled 98 prelude sh. I've heard stories that I cant use the sh tranny. What up? It going in a eg cx w/z6 power for now.
low13da9
Mar 18, 2012 09:59 PM
Tom123456
May 19, 2006 04:25 AM
civic01mtx
Jul 8, 2004 12:49 PM
blackhyb
May 28, 2002 06:12 PM
Integra Baby
Jan 16, 2002 12:35 AM
