H22A4 Flywheel ques
New to board, awesome forums guys
Quick question, are all the bolts (of the 8) for the OEM flywheel right hand loosening, Im havin a beotch of a time removing the final one. Ive searched everywhere and cant find an answer.
Note: This is my first H22 into civic sawp, will an edelbrock intake manifold fit in a 92-95? I've seen that the clearance is mean tight. Any thoughts? Skunk2 a better choice?
Thanks
Thanks
the only manifold that will easily fit is the stock one. the euro r manifold requires that you move the brake prop valve to clear that iac.
as for the flywheel bolts, they are normal threads.. righty tighty, lefty loosey
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">the euro r manifold requires that you move the brake prop valve to clear that iac.</TD></TR></TABLE>
I think you are thinking of shunk2, not EuroR. Euro-R has better clearance than shunk2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">euro r wont fit.... we put one in my buddies 94 coupe.. iac wouldnt fit at all..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">ill verify that as well i have a auro-r in my civic as well and the iacv will not fit without moving the prop valve, thats why i blocked it off and put it on the firewall for now.</TD></TR></TABLE>
Both EGs? What mounts on both or your cars (that you are talking about). Darkknight's is with HCP mounts and it is a EK.
meagainsttheworld
Sep 3, 2006 10:45 AM
