H22A setup
Old Apr 3, 2003 | 04:31 PM
  #26
h22 civ's Avatar
Default Re: H22A setup (redlineh22a)
I say custom made because the stage 1's have been discontinued. But DSS will make them if ordered, i think $100 cheaper. The only dif is the level 1's have a stonger inner, good for 20 more hp at the wheels. You order the axles with either the accord or lude inter. If you have the lude use the lude. The axles are also custom to the mount kit you are using.
I almost made the mistake of using teg axles, didn't know about DSS till i asked around on here.
Old Apr 7, 2003 | 07:27 PM
  #27
SilverJdmhatch's Avatar
Default Re: H22A setup (h22 civ)
thanks everyone fot repyling back
Old Apr 8, 2003 | 08:41 AM
  #28
H22CRX's Avatar
Default Re: H22A setup (SilverJdmhatch)
I have Raxle axles in my car now and have had no problem with them. I took some measurements and told Marty what they were and he made them, fit great. But I've only had the swap done for about 2 months so..
Old Apr 8, 2003 | 08:46 AM
  #29
EKhothatch's Avatar
Default Re: H22A setup (H22CRX)
Has anyone used slicks with the Raxle axles? What your experience with them?
Old Apr 8, 2003 | 09:03 AM
  #30
Newman's Avatar
New User
Default Re: H22A setup (inline4hatch)
Never seen Raxle axles used with slicks on a H22 Civic.... but I've seen it snap/scheer right at the splines when hit with only a 50 shot of NOS. I've launched my H22 Civic on 22x7x13 slicks at 5000 pretty hard numerous times and the axles on my car had held up w/out any problems, but then those were stock Honda-replacement axles (90-91 Integra axles w/out any modifications). I don't know if it was just a bad batch, or if Raxles had the wrong length, or if the metal alloy used to make the joints were weak, but whatever I've seen them break. But again that was with one situation.... I've heard good things and bad things about ALL axle companies so it's really a toss up on what you want to run, what you are willing to trust, and how much you are willing to spend.
Old Apr 8, 2003 | 10:29 AM
  #31
redlineh22a's Avatar
Default Re: H22A setup (Newman)
You can use 90-93 teg axles right?
Newman, I just noticed you have 90-91? Is that what you need with the accord midshaft or will 92 and 93 work also?
Thanks
beyond305
Dec 29, 2012 03:15 PM
twilightprotege
Oct 14, 2007 06:15 PM
bart
Sep 15, 2002 01:18 PM
hb_racer
Aug 29, 2002 10:34 AM
myb18c5
Jun 25, 2002 04:22 AM
