h22a injectors
Old Jun 25, 2003 | 12:58 PM
tiaccordsh's Avatar
Default h22a injectors
I did an obd1 conversion (from obd2) and I just got around to swapping injectors. My question is, are the positive and negative wires swapped between the obd 1 injectors and obd2? onthe obd1 there are a ton of red and black wires, on obd2 there are a ton of yellow and black wires. should I assume the multiple sets of each type go together? As i have it wired now, that is not the case, and it is running like ****. However that could be any number of other reasons. Thanx in advaced.
jinxster
Jun 24, 2004 02:33 PM
tiaccordsh
Jun 25, 2003 03:24 PM
