H22 Wiring
Old Jan 3, 2004 | 08:42 PM
MidoriEK4's Avatar
Default H22 Wiring
I just wanna confirm this from all the reading I have just done in the last hour. I will be putting a H22 into my EK hatch, 96. Now I use the 96-98 EX harness and a Euro Spec H22 Distributor. Everything should be pretty much plug and play except extending the wires correct?
Old Jan 4, 2004 | 09:55 AM
MidoriEK4's Avatar
Default Re: H22 Wiring (MidoriEK4)
No one?
Old Jan 4, 2004 | 10:03 AM
H22EK's Avatar
what year is the motor?
Old Jan 4, 2004 | 12:28 PM
MidoriEK4's Avatar
Default Re: H22 Wiring (H22EK)
hopefully a 96+ H22. did they even make a obd2 h22? another question, dizzys that are obd2 are they the same plug and wiring from obd2a and obd2b?
Modified by MidoriEK4 at 3:47 PM 1/4/2004
Old Jan 4, 2004 | 05:22 PM
MidoriEK4's Avatar
wow some hybrid form
Old Jan 4, 2004 | 06:12 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidoriEK4 &raquo;</TD></TR><TR><TD CLASS="quote">hopefully a 96+ H22. did they even make a obd2 h22?</TD></TR></TABLE>
Yes the did. The made the H22a up to 01. '96 h22a was the same as the OBD1 (engine, closed deck) but they changed it to OBD2. '97 - 01 had open deck (what makes them a better motor to boost, in stock form). 92-96 = H22a1, 97-01 H22a4.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidoriEK4 &raquo;</TD></TR><TR><TD CLASS="quote">another question, dizzys that are obd2 are they the same plug and wiring from obd2a and obd2b?</TD></TR></TABLE>
I really not sure what you are asking, but I will take a stab at it. OBD2 a/b have the same connectors. When you do the swap, it will really not matter what verison the motor is. You may have to do a little research about matching up the wire colors.
Old Jan 4, 2004 | 06:35 PM
MidoriEK4's Avatar
Default Re: H22 Wiring (turbogixxer)
see but if i use the 96-98 EX harness thats obd2. now if i use the euro spec h22 dizzy that is obd2 everything should be plug and play correct?
Old Jan 4, 2004 | 06:49 PM
H22EK's Avatar
yes
MidoriEK4's Avatar
all i have to really do is extended the some plugs correct?
Old Jan 5, 2004 | 02:35 AM
Maintenance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidoriEK4 &raquo;</TD></TR><TR><TD CLASS="quote">all i have to really do is extended the some plugs correct?</TD></TR></TABLE>
yes, And adding wires such as vtec oil pressure, vtec, wiring in injector resistor box, wiring in secondaries, changing out your fuel injector plug to h22 injector plug so your harness can plug up to the h22 injectors, and of course extending some wires. But when you do the swap you'll be able to figure out what wires need to be lengthen.
And if you want to you can wire all the egr components if you want. I didnt because i didnt have all the egr parts and i live where they dont smog me, just safety inspection.
I dont know for sure if the distributor will plug up to civic harness. You might have to repin it. Like i said you will be able to figure things out when you work on it.
What ecu will you be using? I'm assuming obd2 ecu? If you cant find one just use the obd1 p13 w/ jumper harness.
Future.
11
Oct 25, 2005 02:41 PM
knockout
Feb 17, 2005 05:05 PM
kevinm1981
Mar 7, 2004 06:35 AM
ProjectH22Accord
Mar 6, 2004 02:57 PM
Drews Bitch
Feb 20, 2003 06:30 PM
