H22 Timing Issue
Old Nov 13, 2012 | 06:34 AM
alonso25's Avatar
Default H22 Timing Issue
Hello guys, does anyone know if the only way to time H22s is through the flywheel. I've heard they can't be timed like B series with the Cam Gears. I have an H2B with the B series Flywheel and it does not have the TDC mark on it, so that's why I'm wondering if there's any other way to time the H22 besides the flywheel. Thanks in advance.
Old Nov 13, 2012 | 06:46 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: H22 Timing Issue
Do you have an h2b kit? If so, which one? There is usually a timing mark on the flywheel spacer.
Old Nov 14, 2012 | 06:58 PM
blueballsh22's Avatar
are you reffering to mechanical timing or ignition timing? since u said timed with the cam gears i assume ur talking about mechanical and if thats the case the lower pulley on the crank has a mark which lines up with a mark on the oil pump housing and then the cam gears have lines which match up...
kazaa1872
Jan 26, 2009 11:38 AM
b18c1civic95
Jan 1, 2007 06:25 PM
dahoopdahup
Nov 21, 2005 05:06 PM
92 in the works
Feb 23, 2004 07:30 AM
bgod
Jul 23, 2001 06:37 AM
