H22 in EG (Vibrating)
Old Sep 26, 2002 | 09:31 PM
hwnstyle21's Avatar
Default H22 in EG (Vibrating)
This is the deal. After the swap the motor seems to vibrate my car. I didn't have any problems with my B20 VTEC swap. Is this normal for H22's in an EG? Oh yea I'm using Place Racing mounts. Thanks guys
Old Sep 26, 2002 | 09:35 PM
hondaZvic's Avatar
Default Re: H22 in EG (hwnstyle21)
what kind of vibrating... just at idle? or all the time? or when u hit a certian speed?
Old Sep 26, 2002 | 09:50 PM
Jonathan_ED3's Avatar
I seem to hear nothing but bad things about that kit
I know with the Hasport or the HCP kits it vibrates a TAD bit....but that's usually the case with any stiff mounts.
Old Sep 26, 2002 | 09:55 PM
hondaZvic's Avatar
Default Re: H22 in EG (hot_EG)
oh sorry!!!! i missed the part where u sed place racing.. haha..im stupid.. thats what i have too
my car vibrates at 30 MILES PER HOUR thats it.... then and only then it shakes pretty bad... dont know why?.. but it runs good
Old Sep 27, 2002 | 05:04 PM
Puento Racing's Avatar
Default Re: H22 in EG (hondaZvic)
I used the place racing mounts in my pervious h22 hybrid, i didnt get much vibration, any that was noticable.
Old Sep 27, 2002 | 05:08 PM
Kamin's Avatar
did you torque the mounts in the correct ORDER and strength?
Old Sep 27, 2002 | 08:53 PM
JeffS's Avatar
The mounts are likely allowing more vibration than the B20 mounts (assuming you were using stock ones on the B).
Old Sep 29, 2002 | 02:12 PM
MPower332TI's Avatar
Default Re: H22 in EG (JeffS)
well the place racing mounts are solid mounts...u will get a little vibration here and there...also i have place racing and im very happy with them so far...as far as bad things about them i havent heard any.. i almost bought the hcp kit...i called about 6 shops that do the h22 swaps often and asked what they would use..oddly they all said to use place racing...so who knows...only thing ive heard about hcp is it breakig the side oil filled mount cause they dont supply one with the kit..
Old Sep 29, 2002 | 03:20 PM
Newman's Avatar
New User
Vibration usually is one of three things... and in this order from the most common to the least common.....
1) Axle (wrong configuration)
2) Motor mounts not tightened down enough
3) Transmission (very rare but I've seen it)
Check the axles first Usually the culprit
Old Sep 29, 2002 | 07:43 PM
Jason kiDD's Avatar
Be more specific. Is it at idle or during driving?
Old Sep 30, 2002 | 04:01 AM
cccya's Avatar
Default Re: H22 in EG (Jason kiDD)
bump for a good question.
Old Sep 30, 2002 | 01:01 PM
BigBank420's Avatar
Default Re: H22 in EG (cccya)
Did you put a new timing belt on? If so you could have the balance shaft belt off causing the vibration. If that is off at all you will have problems. I would double check that. Hope that helps.
SuperTuner12010
Apr 15, 2009 09:34 AM
JDMbiAtcH
Jul 24, 2007 01:42 PM
ViperRedCRX
Nov 8, 2004 03:14 PM
