H22 EG Reliability Issues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">now that you mentioned the speedo thing, I tried a d series(thats what the guy told me)VSS and it was still inaccurate by the same amount.
I wonder if voltage wise we could trick the ECU?</TD></TR></TABLE>
Actually, Jon is gonna test the yellow box speedo corrector. I wanna buy me this as well to test.
I wonder if voltage wise we could trick the ECU?</TD></TR></TABLE>Actually, Jon is gonna test the yellow box speedo corrector. I wanna buy me this as well to test.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB »</TD></TR><TR><TD CLASS="quote">I want to know HONESTLY what type of reliability issues that you guy's have w/ your swaps. </TD></TR></TABLE>
Had a H22 EG hatch.... sold it
Currently have a H22 EK hatch.... needs exhaust & a paint job
Working on a H22 EF... should be fun
In all honesty, the H22 is totally streetable (even more so than my old turbo B20 setup, which was still streetable but not as much, IMO, than the H22). I've taken my cars to the drag strip and road race course.... the H22 Civic setup holds up well on both tracks and performs well with the right suspension setup but is still totally driveable with a "stock" suspension setup - https://honda-tech.com/zerothread?id=183552
Heh... sorry for the late post but I've been on "vacation" for the past 5 days so I haven't really been on the boards lately
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
Actually, Jon is gonna test the yellow box speedo corrector. I wanna buy me this as well to test.</TD></TR></TABLE>would like more info on this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk »</TD></TR><TR><TD CLASS="quote">Wait...Is everyone here having problems with there dss axles or there stock axles? Are the dss axles too short or something?</TD></TR></TABLE>
All depends on everyone's car and their setup (suspension also). On my EG hatch, I never had any binding problems and I was running 90-91 Integra axles on both sides, and the 90-93 Accord intermediate shaft. But then my car was also only lowered maybe 1.5" and I had a camber kit, which made my knuckles straight, putting less stress on the axle joints.
On my EK hatch, I have the same setup, but I'm using an 89 Integra driver side axle because I had some binding with the 90 Integra axle... same mid shaft. I think my suspension is tweaked on the car, but no problem because I'm going to be putting in an ITR 4-lug suspension setup (straight knuckles w/brand new Civic upper A arms) and using a camber kit, so I'll see what works with that setup.... just need to find time to throw it on
Basically, everyone's car is different so different setups will work on other cars. But there are some things that can be done to help out the axles - check out what I wrote up awhile back.... https://honda-tech.com/zerothread?id=434668
Mine just turned a year old this past weekend. Ive put just over 20k on it since the swap. Ive made MANY long distance trips in it, the cars been great. The last long trip I averaged 33-35mpg (accord tranny helps)
Later IZ
Later IZ
On a side note, how do you turn your idle up a bit? using the physical screw that holds the throttle body open a bit, or some other method? The book says do not touch that screw, it's preset at the factory blah blah, but then again, that motor was preset in a prelude....
Anyway, I have the 'dash vibrating off' shaking at a stoplight due to the low idle and urethane mounts. it's totally fine, but for comfort I'd like to turn my idle up to around 900-1K RPM. Just don't want to mess with that screw if it's gonna frig something up ya know?
So people w/ DSS Stage 1's haven't had ANY issues w/ the Hasport Kit? I'm sorry for beating this in. But I get one motor swap and I would really like to get one that works out.
My car right now idles so rough (she's runnin on 3 cylinders w/ the CX motor
) So I think I can handle a little shaking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB »</TD></TR><TR><TD CLASS="quote">So people w/ DSS Stage 1's haven't had ANY issues w/ the Hasport Kit? I'm sorry for beating this in. But I get one motor swap and I would really like to get one that works out.
it's the other way around, I rarely hear DSS problems with the HCp mounts.
</TD></TR></TABLE>it's the other way around, I rarely hear DSS problems with the HCp mounts.
it's the other way around, I rarely hear DSS problems with the HCp mounts.</TD></TR></TABLE>
And thats the way it really is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB »</TD></TR><TR><TD CLASS="quote">So you guy's are saying the HCP kit, has the axles at better angles then the Hasport?</TD></TR></TABLE>
IMO yes.
IMO yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yayaRl337 »</TD></TR><TR><TD CLASS="quote">you will wish you had not of done it to your daily driver</TD></TR></TABLE>
Why? (seriously curious because I want to do the right thing first)
_______
What are you talking about????? Do it right and there is nothing to sweat
Maybe if you dont know what your doing you could screw the reliability of the car up. Mines got 20k on it since swaping it, in just over a year. My daily driver
Later IZ
_______
Later IZ
Why? (seriously curious because I want to do the right thing first)</TD></TR></TABLE>
100% not true.
100% not true.
The only thing keeping me back from this swap is the axle issue.
Poision- I know you have a slammed car w/ the H22. You have the HASport Kit w/ dss stage 1's correct? How long have you had the swap with your car lowered this much? How many axles have you gone through? Is there ANY way I could get a few pictures of the axles from ya. My car is lowered 2.5"f and 2.25"r with H&R Race Springs. Will this be too much of a drop for the DSS Stage 1's to handle? I know I'm probably being really annoying with a billion questions, most of which are the same and asking in a different way
Thanks alot
Scott
Thanks alot
Scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB »</TD></TR><TR><TD CLASS="quote">The only thing keeping me back from this swap is the axle issue.
Thanks alot
Scott</TD></TR></TABLE>
Yep, HASport kit with DSS Stage 1's.
I actually have a butt load of new high quality pictures for my Digicam, but since I have formatted my computer, I can't find a friggin driver to upload the pictures.
Here is some of the older **** quality, though.
I will be sure to post them up for you when I get the driver.
EDIT - we-todd-did-racing.com is going EXTREMELY slow. I'll post 'em up tonight for you.
Thanks alot
Not any driving or anything issue. The issue I've been having that I need to call Frank at DSS about is the passenger axle inner CV joint comes out about 1/4" of an inch every once in a while and is not fully 'clicked' in, making me leak tranny fluid sometimes.
Extremely annoying, but I've been procrastinating calling him.
No vibration, binding or anything of that nature though.
my h22ek has been totally reliable.. i had some axle and vibration problems at first, but now no vibration at all!! the only problem i am having is a contiuous rev at idle.. anyone know how to fix?? i have tried tightening the diaphram under the TB... what else??
tealchief
Transmission & Drivetrain
Jan 28, 2010 08:35 PM
vy3tnamezz
Aug 31, 2007 05:39 AM
acclude23vtec
Nov 24, 2005 11:25 AM
