GSR Throttle Cable
Old Jul 23, 2003 | 06:59 AM
vultron's Avatar
Default GSR Throttle Cable
I need a gsr throttle cable for my EG swap. i am going to order it from http://www.acuraautomotiveparts.org
can someone please tell me which number it is on this pic. thnx
its gotta be 9,10, or 11
and which other parts to do i need to go with that cable.
Old Jul 23, 2003 | 07:20 AM
syndicate43's Avatar
Default Re: GSR Throttle Cable (vultron)
looks like it is number 9 but I am having a hardtime seeing it. you could save yourself some money and use the eg cable you may have to make yourself a bracket of some sort though
Good luck
Modified by syndicate43 at 4:34 PM 7/23/2003
Old Jul 23, 2003 | 07:25 AM
vultron's Avatar
Default Re: GSR Throttle Cable (syndicate43)
i read somewhere that you are better off using a GSR cable. less headaches
Old Jul 23, 2003 | 07:34 AM
on all the swaps I have ever done we have used the stock cables and had no problems
Old Jul 23, 2003 | 07:39 AM
vultron's Avatar
ok what kind of bracket would i have to make? i dont know if i will have the resources to do such a thing...
Old Jul 23, 2003 | 07:57 AM
I will try to get some pics for you but all you neeed is a drill pliers and a strip of metal you can pick that up at your local hobby store
Old Jul 23, 2003 | 08:00 AM
SpyderZEX's Avatar
I'm using my civic cable on my B18C swap for now. Works just fine, no problems...
Old Jul 23, 2003 | 08:13 AM
vultron's Avatar
Default Re: GSR Throttle Cable (SpyderZEX)
and you have an EG? i thought the stock EG cable wasnt the correct length for a b18c1 swap... my motor is jdm btw. i dont know if that matters.
Old Jul 23, 2003 | 11:00 AM
SprayinCX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyderZEX &raquo;</TD></TR><TR><TD CLASS="quote">I'm using my civic cable on my B18C swap for now. Works just fine, no problems...</TD></TR></TABLE>
we held up my stock cable on my 92 cx and the 95 gsr cable next to each other. they measured the exact same thing.
Old Jul 23, 2003 | 09:48 PM
vultron's Avatar
Default Re: GSR Throttle Cable (SprayinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">
we held up my stock cable on my 92 cx and the 95 gsr cable next to each other. they measured the exact same thing.</TD></TR></TABLE>
so are you saying all i need is the bracket which is #13 in the pic (thanx to Bseries)
Old Jul 24, 2003 | 04:11 AM
VTECVillain's Avatar
For the best possible cable setup, definitely get the GSR cable and bracket that mounts to the firewall. The stock cable will work but the GSR cable and bracket is perfect for the best function and fashion
I have never measured the length of a Civic cable to a GSR cable. Although they might be the same, the threaded end the mounts to the throttle body is different.
You'll need to get bracket #13 and either cable #10 or #11 (hard to tell by the pic) from any 94-01 GSR as they are the same. The bracket will bolt to the firewall with a 10mm bolt and there is a threaded hole already there.
Old Jul 24, 2003 | 09:18 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyderZEX &raquo;</TD></TR><TR><TD CLASS="quote">I'm using my civic cable on my B18C swap for now. Works just fine, no problems...</TD></TR></TABLE> me too.
Old Jul 24, 2003 | 12:42 PM
not133t's Avatar
i have a gsr throttle cable im willing to sell! let me know
Old Jul 24, 2003 | 05:35 PM
SiR831's Avatar
check your email
oneEg1Tc
Mar 27, 2010 07:18 PM
eggsi619
Jun 29, 2009 11:14 AM
Civichx1998
Nov 27, 2006 03:58 PM
2SLO
Jan 2, 2003 01:33 PM
