GSR swap to Civic EK???? OBD2!!!
How do you connect the v-tec wire into the GSR ecu pin which is so little? There are 3 wires for the crank angle sensor comming from the civic harness, but there are 2 wires for the gsr's engine for the crank angle sensor??? what do I do?
This link should help you... http://www.jspectuning.com/6gen/
I'm trying to do the same put a b18b1 with GSR trans into my 2000 EK sedan but I'm having issues with the crank shaft position sensor not plugging in. I used my y8 harness on the b18b1 everything plugs in but the crank shaft sensor. I used the b to d adapter on my ECU. I'm totally lost on what to do cars been sitting for a year 😔
Cranks and cranks but won't start
enot767
14
Jan 5, 2011 07:27 PM
sillyme77
Dec 21, 2006 04:54 PM
