gsr secondaries.
I just installed a 95 gsr motor in a 94 civic ex. I'm running a p28 right now that I'm chipping with a skunk 2 program. Now, I know the p28 doesn't run knock sensor or IAB, so my question is........... If the IAB isn't wired up are my secondaries going to work?? if not, how do i got about getting them to work. thanks.
You can't get them to work. Unless you can some how wire a 5600 to 6k rpm pill to activate the iab box. With out the p72 good luck.
Or you can do what I did. Buy a skunk2 manifold. I also have a p28 chipped mugen program.
[Modified by TurboB16Coupe, 10:10 PM 3/29/2003]
so unless I do one of those options my motor won't run full potential?
skunk2 manifold in my opinion, like VTECvillan said, they will set you back the same amount, and the skunk2 manifold will be something you will probs want later anyway.
If you aint got $$$ for Skunk2 mani... then just take out your butterfly plate & dont worry about it.
If you feel lazy... then just stick your butterflies open & still dont worry about it
Pete
Pete
cthan3o3
Aug 10, 2005 10:21 AM
mr2turbo007
Dec 12, 2004 07:43 PM
Evil_Wizard
Mar 19, 2002 02:25 PM
