GSR motor sensor?
I have a 94 gsr motor going into a 98 civic. I have one sensor that is broke. I unscrewed it out of the block. It was below the intake manifold, kinda hard to get at. Is this the crank sensor? If so I need one. Also I need a 99 si rear mount bracket. If anybody knows what sensor that is or has any of the items I need please let me know....
Thanks
Thanks
Is it on the back of the block under the intake manifold? If so, it's the knock sensor. The crank sensor (CFK) is on OBD2 USDM motors and is bolted to the oil pump, you can't access it without taking off the lower timing shield.
Thanks. Okay so its the knock sensor. Does anyone have one I can buy? Also a 99 si rear mount bracket. Also I have a evap purge plug not connected to anything. Do I use this?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civic94gsr »</TD></TR><TR><TD CLASS="quote">Thanks. Okay so its the knock sensor. Does anyone have one I can buy? Also a 99 si rear mount bracket. Also I have a evap purge plug not connected to anything. Do I use this?
Thanks
either junkyard or the stealership for the knock sensor and mount bracket. cheaper to go through the junkyard.
Thanks
Alright thanks for clearing things up for me.
Needed for 94 gsr motor :
Knock sensor
99-00 civic rear bracket
1- stock injector
If anyone has any or all of these parts you can reach me at 231-884-1273 or email me at raptoraja@yahoo.com
Thanks
Knock sensor
1- stock injector
Thanks
93(Civic)EG6
Sep 28, 2006 01:43 AM
