gsr bottom end?
well as my sig. says, ive got a b16a, but as everyone knows, they've got no torque. i was wondering how difficult it was to swap a gsr bottom end in, and if it was worth it? thanks for the help.
its a good idea to keep your b16 pistons to have higher compression.
poor man's type r is a nice setup.
def worth it....he was refering to putting your b16 pistons in the gsr block which will yeild higher compression than the gsr pistons...you will actually lower compression if you use the gsr pistons.
but if you are goin to buy arias pistons anyways then it doesnt matter
you are talking 11.42:1 compression with the b16 pistons. If he keeps the gsr pistons he is only at 10.04:1.
http://www.c-speedracing.com/howto/c...c/compcalc.php
very nice tool there.
**** guys, thanks for all the help. sounds like doin this is a good idea. thanks again for all the help, i appreciate it.
I'm planing on doing the same set up (poor man's type-r) with boost, but I can't find a gsr shortblock. Good luck
vlc92189
22
Sep 4, 2007 10:07 AM
