GOD DAMN THIS SWAP (wont start)
#26
Re: Re: (Kamin)
I feel your pain. My friends put together a B16a2 and all the timing was off (cams, ignition, and firing order). Man, that was not cool. But hope that you get the timing squared a way.
[Modified by turbogixxer, 11:36 PM 3/28/2003]
#30
Re: Re: (poison)
i couldnt see from the above posts, did you double cheack to see if the cam gears are lined up tdc
if they are one notch ahead (adnvanced) it will have weanny power. if it reversed, it will most likely not start
#33
Re: Re: (Kamin)
hahahahahaha it just keeps getting better
well firing order is now correct but no spark from distributor (wich WAS there 24 hours ago, but weak)
pulled cap, the rotor is charred and so are the prongs on the cap.
i feel so bad for this kid lol
[Modified by Kamin, 11:38 AM 3/29/2003]
#35
Re: Re: (dom93hatch)
yea having an absolute blast
and to top it off while we are waiting for parts for the b16
im about to start a sr20 swap in a s13..
damn i need a bigger garage. too many cars.
#38
Re: Re: (Kamin)
have you checked your ignitor and coil???... maybe its a fuse somewhere.. when i did my swap i had the same prob .. ended up being fuse and cap...
#39
Re: Re: (joshwhe)
dood i just finished another h22a swap for an accord...
what stopped the engine from starting was the distrubutor, i took it off my car and slapt it on it fired straight away...
also i notice that when i had the wrong firing order, when you crank it makes unpleasant noises heheh...
i got new sparks and after cranking it a few times, the plugs were saturated with fuel but they got black after a while, so there is spark... however the dizzy was the problem
[Modified by Ryu, 11:39 PM 4/1/2003]
#45
Re: Re: (hybrider93)
well its a 100% startup warranty
so it WILL start. and if it dont
steve will fix it
[Modified by Kamin, 11:31 PM 4/1/2003]
steve will fix it
#47
Re: Re: (poison)
lol a bad ____ is owning me. (its blank because i dont know the problem! )
i hope its the ignitor or somthing. new dizzy is comming. we shall see.
#48
Re: Re: (Kamin)
Man that blows. It does sound like a distributer problem so hopefully you will have it fixed soon. Sounds like the Ignitor. Its not the coil most likely cause you were getting spark before (although it might be toast now). Good luck and if you have a multimeter handy check all the wires in the distributer going to the ICM and all the sensors. Also if the distributer has ever been tampered with, if the notched piece that goes into the cam has been taken off and put on the opposite way, then the car won't start. Good luck and I'm dying to hear word on that project 240 you've got going on.
#49
Just because you pull a plug and see a spark, does not always mean that the ignition system is up to par. Its far easier to jump the gap in free air than it is in the combustion with a lot more pressure. The better thing to do is to get a spark tester, like a Thexton 404, which allows you to adjust the gap, so as to tax the ignition system harder.
#50
Re: Re: (Kamin)
