Girdle
Old Nov 9, 2005 | 08:39 PM
CRXb18Turbo's Avatar
Default Girdle
I have GSR Girdle with the 3 main plus bolts, tray and pickup.
Do i have to do any grinding to make it fit??
I know my ls pan won't fit... But if I get the GSR pan, Is everything is bolt on?
search and it say to grind the main...
Is that only if i use my ls main???
Old Nov 9, 2005 | 11:44 PM
DSRxMilogen's Avatar
Default Re: Girdle (CRXb18Turbo)
need the windage tray, oil pick up and oil pan from a gsr...
need to machine #3 main cap and barely shave the tops of the numbers on caps numer 2 and 4... search.. theres a post about this with pics..
to be safe!!!
MAKE SURE YOU LINE HONE YOUR MAIN CAPS AFTER THE INSTALL!!!!
Old Nov 9, 2005 | 11:46 PM
Default Re: Girdle (xnorxcalx)
i just re-read your post.. you shouldnt use the gsr main caps.. not sure if they fit or not.. but if you do find a way to use them you would have to get a line hone for damn sure..
Old Nov 10, 2005 | 10:45 AM
any more?
Old Nov 10, 2005 | 11:50 AM
BigJ5's Avatar
A line hone is overkill imo, honda is more than accurate on these blocks. And all the B18's are the same. Plastiguage for cleareance and deal with the bearings, as for the oil pickup, I just cut the legs and rewelded them. I made a custom windage tray from the stock one, and I just used a hammer on the oil pan.
It's not that hard, as for shaving numbers I'm not sure why you would, they face down away from the rotating assembly...I did this a while ago, but I don't recall requiring to do this...
Old Nov 10, 2005 | 02:31 PM
Default Re: Girdle (BigJ5)
Anybody else?
I have GSR Girdle with GSR 3 main plus bolts, tray and pickup.
The girdle is already flush with the GSR main.
abusedvtec
Jul 6, 2009 08:02 AM
dumpeDc2
Oct 7, 2004 03:20 AM
black-hatch
Feb 21, 2003 10:17 AM
DD_JonnyLee
Jan 17, 2003 02:54 AM
88CRXHybrid
Mar 17, 2002 07:15 PM
