full throttle bogg
Old Feb 4, 2005 | 09:58 AM
00ekhatch's Avatar
Default full throttle bogg
-97 gsr in a 00 civic dx using SI computer.. the engine runs, vtec wrks properly.. no check engine light, but if i press throttle more than 3/4's the engine boggs BAD.
this trigures the check engine light and the computer reads code 1106 or barometric pressure sensor (located inside the ecu).. i thought a solution would be to change ecu's. i did. another SI computer and the car engine behaves in the same manner... any ideas as to why it would register the same code and behave the same with differant computers? anything would help at this point.
Old Feb 4, 2005 | 06:58 PM
00ekhatch's Avatar
Default Re: full throttle bogg (00ekhatch)
any body?
Old Feb 4, 2005 | 09:51 PM
JDMotive's Avatar
The problem sounds similar to the problem you get when the ouer two wires of the tps are swapped.Try swapping those.
Old Feb 5, 2005 | 02:27 PM
00ekhatch's Avatar
Default Re: full throttle bogg (JDMotive)
i would not think that since the wire harness was not cut at the TPS sensor... i am now leaning towards the IACV since the B18 is a 2 wire sensor and the civ's stocker was a 3 wire.. i have located the wiring info to check for proper install -anyone correct me if this is wrong:
in plug B: pin# 6 needs to be moved to pin# 23 (black-blue) and pin# 15 (orange) is to be removed..... and further more.. would a problem with the IACV cause the engine to BOGG under full throttle conditions
Old Feb 6, 2005 | 06:15 AM
fastwanabe's Avatar
sound loke your bogging cause by the TPS, you have the wrong connector hooked to the TPS. It quite common actually for people to confuse the IACV connector for the TPS and haver them backwards.... at least on EG's.
Old Feb 7, 2005 | 10:29 AM
00ekhatch's Avatar
Default Re: full throttle bogg (fastwanabe)
no i checked the sensor plugs.. iacv plug is 2 wire plug, and the TPS sensor is a 3 wire, they wont fit on the wrong terminal... they are in the correct location..
ANYONE HAVE EXTENSIVE KNOWLEDGE IN EK9--> B SERIES SWAPS, AND HAS ANY OTHER IDEAS?
Old Feb 8, 2005 | 11:54 AM
brnyrdcmndo's Avatar
Bump, for a buddy?
Old Feb 9, 2005 | 07:35 AM
00ekhatch's Avatar
could it be as easy as getting the obdIIb to obdIIa jumper harness and run the gsr ecu?
Old Feb 10, 2005 | 11:58 AM
00ekhatch's Avatar
i disconected the TPS sensor completly to test your theories, thanks for your knowledge because the engine now is performing at full throttle but has no VTEC because it throughs a cel... after work i will check the wiring to determin if it is a factor or if it is the tps sensor itself... how do i check to make sure the TPS is wrking properly? what should it read on a voltmeter?
Nay
May 10, 2017 11:05 AM
JasonLX
15
Nov 19, 2009 12:54 PM
xkrazyxjbrkerx75
Sep 2, 2009 06:31 PM
AkureiKami
Jul 28, 2009 01:09 PM
MASTERJDM
May 14, 2006 11:38 AM
