Fuel Pressure and Timing
Old May 28, 2003 | 05:58 AM
GsTeg90's Avatar
Default Fuel Pressure and Timing
Can someone please help me. My car is backfiring and cant keep up with cleaning my bumper from all the black stuff coming from my exhaust.
Heres my setup. i would like input on what my fuel pressure should be and my timing.
currently set to 40psi vaccum in and timing is 16deg and vafc is +2 all accross.
car is backfiring but plugs are still on the white side.. so i dont know whats happeneing.
b18c1
pr3 piston
Port/Polish
Skunk2 Im
Dc 4-1 Headers
ITR camshafts
AEM Cam Gears
B&M Fuel reg
JDM h22a Injectors
VAFC
2.5 custom exhaust
with the pistons and the head shave compression is at 11.7:1
this is in a 90gs with a pr3 ecu /mugen chip to disable 2nd o2sensor
All help is greatly appreciated.
__________________
GsTeg90
erassi@hotmail.com
Modified by GsTeg90 at 9:23 PM 5/28/2003
Old May 28, 2003 | 11:04 AM
myhatchrips's Avatar
Default Re: Fuel Pressure and Timing (GsTeg90)
this might help....bump your fuel psi to 46 psi with vacumm on. if you have cam gears advance them +2 degrees on the intake and +1 degree on the the exhaust side. set your ignition timing to 18 degrees. i can almost guarantee you that your car will run much better. let me know the results. peace
Old May 28, 2003 | 12:06 PM
GsTeg90's Avatar
what about the VAFC. bring it back to zero? i have aem cam gears ,dont you thinks that advancing too much?
i just dont want to cause any damage.
GsTeg90
Modified by GsTeg90 at 9:24 PM 5/28/2003
Old May 28, 2003 | 04:58 PM
GsTeg90's Avatar
bumped the fuel pressure car bogs before hitting vtec , sounds like it cuts off.
Anyone?
Old May 29, 2003 | 05:19 AM
GsTeg90's Avatar
Any more input would be greatly appreciated.
GsTeg90
Old May 29, 2003 | 09:43 AM
bottlefedb18c1's Avatar
Default Re: Fuel Pressure and Timing (myhatchrips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips &raquo;</TD></TR><TR><TD CLASS="quote">this might help....bump your fuel psi to 46 psi with vacumm on. if you have cam gears advance them +2 degrees on the intake and +1 degree on the the exhaust side. set your ignition timing to 18 degrees. i can almost guarantee you that your car will run much better. let me know the results. peace</TD></TR></TABLE>
just wondering how did you come up with the +2 deg on the intake and +1 deg on the ex how will that affect the engines preformance
Old May 29, 2003 | 11:53 AM
GsTeg90's Avatar
I did'nt touch my cam gears... scared of causing any problems..
Anyone?
GsTeg90
Luisrivera25
15
Dec 7, 2011 12:44 PM
ej1vtec
Jun 6, 2006 08:17 AM
Boosted Gsr Hatch
Mar 9, 2003 06:58 AM
Vtec integra
Apr 27, 2002 08:59 PM
VTECHGSR
Oct 30, 2001 01:44 PM
