Found a Problem with my vtec, need help
Hello, four a few months now i have had my b16a swaped into my 89 crx dx. Ever since i got the motor in there i havent been able to get vtec working. (IACV code and Knock code) So i went crazy and ripped ever peice of wire protector on my entire harness off and found that there was a black wire not conneted to my knock sensor, just and orange wire. Im not a big wiring person so i need to know if that black (i Guess ground) wire goes there and were i can get a pin to go into the sensor connection so i can attach the wire. I got the vtec harness from hasport, i dont understand why they had that wire hidden........those bastards.
As for my idle air valve, i have replaced the unit and checked the ecu and it appears the right color is in the right spot.. if you can help that would be great.
thank you, Travis
thank you, Travis
juicy.koreans.suck
Dec 25, 2001 01:54 PM
