Finished EK h22 Swap
#32
Re: Finished EK h22 Swap (=GAMEOVER=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= »</TD></TR><TR><TD CLASS="quote">looking good. what is your axle setup if you dont mind?</TD></TR></TABLE>
Driveshaftshop axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorHB »</TD></TR><TR><TD CLASS="quote">What kinda motor mount kit did you use? Seems to sit kinda close to the firewall.</TD></TR></TABLE>
HCP mount kit
HCP mount kit
#36
Re: Finished EK h22 Swap (Jago)
nice swap. i'm thinkig about doing the same to my 95 hatch. i heard that some mount kits angle the drive axles forward making them prone to snapping. does your kit do that? and how much wiring was there? and did you make any space to replace the alt. belt if needed?
#37
Re: Finished EK h22 Swap (lollypopking)
The HCP mounts have a good axle angle, I don't have any binding at all. Running to low a ride height with this swap can cause problems both axles and oil pan clearence. I liftied my ride height a bit after finishing. I used the same belt it just barley clears the headlight, I'll try and take a pic tonight.
#45
yo kurt! this tony. it looks nice man. i havent seen u in forever. but yea hows it running? last time i heard from u, u had problems with...umm some belt i think. i forget.. probably wasn't even a problem. but yea.. its good to hear that its good now.. see ya man!
Modified by 1illAccord at 4:32 PM 11/1/2004
