A few questions...
Old Aug 26, 2003 | 09:30 PM
lcaruca97's Avatar
Default A few questions...
ok here it goes. I have a 94 JDM h22a with a jdm p13 ecu. Which resistor box should i be using? Oh by the way...my car is the same exact thing as a 97 accord ex. Only throwing one code (6 ect) and it runs horrible. Absolutely no power whatsoever. It takes about 40 seconds to reach 40 mph. Any input will be much appreciated.
Old Aug 27, 2003 | 05:32 AM
lcaruca97's Avatar
Default __TTT__TTT__TTT__
ttt
Old Aug 27, 2003 | 08:43 AM
eg6ajk's Avatar
Default Re: A few questions... (lcaruca97)
90-5 accord/prelude or 90-1 integra/civic si will work just fine.
is the water temperature sensor is it connected? how is the compression on the motor???
Old Aug 27, 2003 | 05:01 PM
lcaruca97's Avatar
Default Re: A few questions... (eg6ajk)
update!!! ok, now there is no engine codes except vtec. which isnt hooked up yet (why hook it up if engine doesnt run right?). But it still runs like crap. absolutely no power after about 3000 rpms. Lots of black smoke out of the tail pipe too.
Old Aug 27, 2003 | 07:43 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcaruca97 &raquo;</TD></TR><TR><TD CLASS="quote">update!!! ok, now there is no engine codes except vtec. which isnt hooked up yet (why hook it up if engine doesnt run right?). But it still runs like crap. absolutely no power after about 3000 rpms. Lots of black smoke out of the tail pipe too. </TD></TR></TABLE>
Sounds like a few things that it could be. If you're not getting any other code except for VTEC, check your electrical grounds and ignition parts (distributor, plugs, etc) as it could be missing. Another thing to look into is the fuel, fuel pressure, injectors, filter, etc.
Old Aug 27, 2003 | 07:54 PM
lcaruca97's Avatar
Default Re: A few questions... (Newman)
ok here is the complete setup..
94 Jdm h22a
97 accord injectors
97 accord harness
97 & 94 resistor box (which should i use?)
94 jdm p13
New fuel filter
I previously had about 6 codes, but i have eleminated them all. I replaced the tps and map and rewired the ECT and IAT. SO now the vtec code blinks (22) because i dont have the pressure switch wire connected yet. Going to try and replace fuel regulator with backup tomorrow and see if that helps. I have the timing advanced quite a bit so i can put the car around the driveway and into the garage. Its the only way it will run without dying. I am baffled.
Old Aug 28, 2003 | 05:52 PM
lcaruca97's Avatar
blah.... ttt
Old Aug 29, 2003 | 11:18 AM
lcaruca97's Avatar
new update:
No check engine light at all now. Hooked up the vtec pressure switch.
Still runs horrible
CEL comes on after 4500rpm code 23 Knock sensor (going to investigate that tonight)
Could it be that my fuel pressure is too high? The car spits out lots of black smoke when reved and has virtually no high end power. after about 2000rpms the car goes to bog city.
Any new thoughts?
Old Aug 29, 2003 | 01:02 PM
lcaruca97's Avatar
cmon guys!!! I know i dont have a hatch or anything like that but it doesn't mean you gotta ignore me just cause i gots a pimp acura!!!! Give a fellow honda brotha some help hehehe
Old Aug 30, 2003 | 10:24 PM
lcaruca97's Avatar
yup
smessaert
Oct 3, 2017 06:50 AM
mrbleh
Jan 15, 2014 03:03 PM
1997accordSE
Aug 27, 2012 01:10 AM
kornmanz
Feb 13, 2008 06:03 AM
RabbittZ
Apr 20, 2003 07:46 PM
