My First CRX build thread
Old Mar 22, 2010 | 12:50 AM
rexracer626's Avatar
Default My First CRX build thread
well my rex has been sitting for about a year with now work done since i worked and went to school but now i got laid off so got plenty of time to work on my car. so its going to be slow because i have to save money but here it goes!!
1991 crx si
i have already done......
all energy suspension polyurethane bushings
polyurethane rear trailing arm bushing
skunk 2 rear camber kit
spc rear toe link
Full Race traction bars
steel braided lines
extended wheel studs
what im planning to do.....
SPC front upper control arms
s2000 cluster
s2000 start button
wire tuck
Chase Bays brake line tuck kit
Roll Bar
hydro clutch conversion
Hasport D series Hydro mount kit
Rywire engine wiring
lights wiring
walbro intank fuel pump
T1 battery disconnect
AEM PNP Engine Management
AEM EPM
AEM TWIN FIRE
AEM CDI PENCIL COIL
planning on building a boosted sohc
but first wiring!!!
ripped out all of my crx wiring a decided on a wiring kit for a "hot rod" its called EZ wiring a lot like Painless wiring everything is labeled every 5 inches i believe.
example of labeling on wire
Pics of my dirty a@@ engine bay
Fuse box mounted
tail lights wire routing mock up
made connectors for easy removal of wiring harness
one on the right is for the front lighting and the one on the right is rear lighting
now got to solder these together this the combination switch plug for the turn signals and headlights
mock up of the front wiring
what do you guys think of the rear shade things? keep them?
extended studs haha
i got to do the left side before class..........still not fully mounted
Old Mar 26, 2010 | 06:01 PM
Default Re: My First CRX build thread
added pics!
rexracer626
107
Sep 16, 2013 09:06 AM
rexracer626
Sep 17, 2012 10:00 PM
KaoticSnow
Jan 8, 2007 03:11 PM
mrchris1979
Mar 5, 2006 11:09 PM
range
Feb 2, 2004 11:48 AM
