F20B FAQ
F20B
Accord/Troneo Sir and Sir-T (CF4) (JDM)
197hp@7200/145tq@6600
85mm bore
88mm stroke
145.5mm rods (f20b rod length = 145.425)
1.65 r/s ratio
55mm mains like h22a4 block
rod journal has been offset ground on both sides to the size of a b-series rod journal.
11.0:1cr
smaller, b-series rod journals
beefy rod, like a s2000
23mm wrist pin
exhaust manifold = H22
intake manifold = h22
dizzy = h22
timing belt = unique, uses 156 teeth, you can use a h22 one. (see below)
waterpump = h22
Oil Pan = F23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel »</TD></TR><TR><TD CLASS="quote">
Belt that came with my f20b from h-motors
14400-PCB-004 Teeth count 156
New H22 timing belt part number
1400-P13-003 Teeth count 155</TD></TR></TABLE>
Engine is a mix between the H22A4 and F23
Misconceptions about the F20B:
1. It does NOT come with a single stage intake manifold. That is found on the H22A7 European Accord type R. For everything that you'd ever want to know about that intake manifold click here:
https://honda-tech.com/zerothread?id=1960750
2. It does NOT have type S cams. It is believed that it has the same cams that are found in the JDM H22.
EDIT, 09/11/07: Manual version has type S cams, Auto Version has regular H22 Cams
3. Most engines will be from the automatics which have a smaller tb and weaker camshafts.
F20B Dizzy wiring
https://honda-tech.com/zerothread?id=1957852
Specs of other honda ~2 literish engines for comparison
B20Z = 146hp, 133tq
F20B = 200hp, 145tq
F20C = 240hp, 163tq (JDM)
K20R = 220hp, 158tq (JDM)
H22A = 200hp, 161tq (JDM)
H22S = 220hp, 163tq (JDM)
H23A = 160hp, 156tq
H23VTEC = 197hp, 163tq
k20a2 = 200hp @ 7400, 142tq @ 6000
A few random pics of F20Bs that I've found
A few pictures I took of a F20B
More info to come
85mm bore
88mm stroke
1.65 r/s ratio
11.0:1cr
23mm wrist pin
dizzy = h22
waterpump = h22
Oil Pan = F23
F20B Dizzy wiring
B20Z = 146hp, 133tq
F20B = 200hp, 145tq
H23A = 160hp, 156tq
More info to come
Some water pump and timing belt info.
Water pump part number
19200-P13-003 (Comes with mounting o-ring)
Only ID numbers that I was able to find on both the new and the old pump was "26T P13"
Modified by HeikDiesel at 11:36 PM 6/19/2007
Iron sleeves, Ill count the teeth tonight
Edit....I was very wrong. Old belt has 156 teeth, new has 155
Fixed info
Modified by HeikDiesel at 11:33 PM 6/19/2007
Fixed infoModified by HeikDiesel at 11:33 PM 6/19/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel »</TD></TR><TR><TD CLASS="quote">Iron sleeves, Ill count the teeth tonight
Modified by HeikDiesel at 11:33 PM 6/19/2007</TD></TR></TABLE>
you sure about that? I could have sworn they're FRM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">Your right, it's a small bore (85mm) Iron sleeve. I was thinking type S
Modified by skunked at 4:55 PM 6/21/2007</TD></TR></TABLE>
Cool
I was right for once lol
Cool
So just to clear some issues up on another forum. On the F20b's does it actually have that stamped on the block (I believe they do)? Or does it still have H22 stamped (which makes no sense to me).
Gracias!
Gracias!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportechPerformance »</TD></TR><TR><TD CLASS="quote">So just to clear some issues up on another forum. On the F20b's does it actually have that stamped on the block (I believe they do)? Or does it still have H22 stamped (which makes no sense to me).
Gracias!</TD></TR></TABLE>
Just be like "PWNED BY THE IMG"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">Just be like "PWNED BY THE IMG"
Ahhh! I knew it!
Ahhh! I knew it!
hey on the back of the block there is a neck for a hose near the water pump where does that go on the car, sorry i dont know how to add a picture if u could help with that also thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atlplayer4life90 »</TD></TR><TR><TD CLASS="quote">hey on the back of the block there is a neck for a hose near the water pump where does that go on the car, sorry i dont know how to add a picture if u could help with that also thanks</TD></TR></TABLE>
off the water tube? It goes to the heater core.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">Misconceptions about the F20B:
I am going to have to disagree with this comment. I have had 2 F20B motors and am currently using the F20B cams in my car. I spec'd them and also degreed them in the past. They match up IDENTICAL to the H22 Type S cams listed on the Crower site.
http://www.crower.com/cat/impo...shtml.
Normal JDM cams have the same lift, etc as normal USDM cams. I have dynoed both cams on my motor and F20B cams have much more lift and different duration and ramp angles than normal H-series cams. Here was my dyno comparison: http://www3.telus.net/public/unrynhen/camdiff.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES »</TD></TR><TR><TD CLASS="quote">
Normal JDM cams have the same lift, etc as normal USDM cams. I have dynoed both cams on my motor and F20B cams have much more lift and different duration and ramp angles than normal H-series cams. Here was my dyno comparison: http://www3.telus.net/public/unrynhen/camdiff.jpg</TD></TR></TABLE>
Im curious as to what size TB's are on both of those engines
