engine no worky!!!
Old Jun 10, 2003 | 09:03 PM
lcaruca97's Avatar
Default engine no worky!!!
ok, h22 is in. it looks good, however...it doesn't run. No spark. I have tried just about everything i can think of to remedy the problem, but have not had any luck.
checking grounds
new ICM
good coil
checked wiring about 34956329845 times over
new ECU
I am baffled. If anyone has any ideas, please post!
thanks.
Modified by lcaruca97 at 8:52 PM 6/11/2003
Old Jun 10, 2003 | 09:27 PM
Turbogixxer's Avatar
Default Re: engine no worky!!! (lcaruca97)
your ignitor is most like bad. call the place that you got the swap and tell them that your dizzy is bad and they will (maybe) send you a new one!
PS: if it is Steve from hmotors, he will send one for sure
Edit: thanks poison for the spelling help, another reason for poison to be Mod.
Old Jun 10, 2003 | 09:36 PM
poison's Avatar
Default Re: engine no worky!!! (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">your ingitor (SP?) is most like bad. call the place that you got the swap and tell them that your dizzy is bad and they will (maybe) send you a new one!
PS: if it is Steve from hmotors, he will send one for sure</TD></TR></TABLE>
Could be the ignitor. (kenny )
But I would suggest replacing the plugs, wires, then cap/rotor, and if all else fails, replace the Ignitor.
HTH.
Old Jun 11, 2003 | 11:52 AM
lcaruca97's Avatar
Default Re: engine no worky!!! (poison)
if the ignitor is the little part that looks about as small as a book of matches and has like 4 or so connections comming off it, then i already replaced it. any other ideas?? thanks.
Old Jun 11, 2003 | 12:04 PM
torr's Avatar
check fuses too
Old Jun 11, 2003 | 03:53 PM
lcaruca97's Avatar
Default Re: engine no worky!!! (torr)
which fuses??
Old Jun 11, 2003 | 03:58 PM
976's Avatar
976
New User
ECU and Starter fuses. ECU under hood, starter under dash.
Old Jun 12, 2003 | 12:29 PM
lcaruca97's Avatar
Default Re: engine no worky!!! (w00t!)
all fuses are good. checked every last one of em! I am gonna start pulling hair out soon!!
Old Jun 12, 2003 | 12:33 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcaruca97 &raquo;</TD></TR><TR><TD CLASS="quote">all fuses are good. checked every last one of em! I am gonna start pulling hair out soon!! </TD></TR></TABLE>
Does your CEL (check engine light) come on and go off after 2 seconds when you put the key in the ON position?
Old Jun 12, 2003 | 01:16 PM
lcaruca97's Avatar
yes
no codes yet.
Old Jun 12, 2003 | 01:50 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcaruca97 &raquo;</TD></TR><TR><TD CLASS="quote">yes
no codes yet.</TD></TR></TABLE>
Ok, it's most likely something inside the distributor.
Replace the plugs, then wires, then cap/rotor, and if those fail replace the ignitor.
Old Jun 12, 2003 | 02:24 PM
94CivicSi's Avatar
new ECU</TD></TR></TABLE>
New to you or brand new? Have you tried an ECU you know to be good?
Old Jun 12, 2003 | 02:32 PM
lcaruca97's Avatar
Default Re: engine no worky!!! (94CivicSi)
new from steve. the original one he sent me looked like a veitnam war veteran, it was beat to hell. so he swapped me a new one. oh and i get no cel at all even when i first turn the key, but its hooked up to the right wire.
Old Jun 12, 2003 | 04:02 PM
Kris's Avatar
try what turbogixxer and poison said. it is a common problem that the dizzy and the wires and plugs are bad. Try that and then go from there.
Old Jun 12, 2003 | 04:35 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcaruca97 &raquo;</TD></TR><TR><TD CLASS="quote">new from steve. the original one he sent me looked like a veitnam war veteran, it was beat to hell. so he swapped me a new one. oh and i get no cel at all even when i first turn the key, but its hooked up to the right wire.</TD></TR></TABLE>
dude. lol. I've said the problem several times. oh well.
hope you find the problem.
Old Jun 12, 2003 | 04:58 PM
lcaruca97's Avatar
coil = new
ignitor = new
cap = new
wires = new
spark plugs = new
rotor = new
Old Jun 12, 2003 | 05:53 PM
Kris's Avatar
check if you have power to the coil.
Old Jun 14, 2003 | 07:06 AM
94CivicSi's Avatar
Default Re: engine no worky!!! (Kris)
How's it going man? Any luck yet?
Old Jun 14, 2003 | 07:39 PM
fastwanabe's Avatar
are you sure your OBD2&gt;OBD1 harness is good? I suggest you check the harness on a different car to make sure.
Old Jun 23, 2003 | 04:25 PM
lcaruca97's Avatar
Default Re: engine no worky!!! (fastwanabe)
arghhhh, ok here is an update.
rechecked everything...
coil is good
ignitor(icm) is good
new cap
new rotor
everything has power inside the dizzy
new ecu
injectors pulse when the car is on
no check engine light, not even when key is turned on
i smell fuel when i crank it
Old Jun 23, 2003 | 10:00 PM
bagged89hatch's Avatar
there is a ground wire in the engine harness that bolts on with a 10mm bolt to the thermostat housing if it is off you will not get spark. i dont know if this is your answer but i sure know that me and my friend pulled our hair out for two days tring everything like new coil other dizzys everytyhing and it was a bastard ground off on the thermostat housing. let me know if this helps
also even if the ground is off you will still get power at the dist and ground and all that jazz. i cant stress it enough grounds are everything check em again if you cant findthat ground email me ill send you a pic
Old Jun 25, 2003 | 11:51 AM
lcaruca97's Avatar
Default Re: engine no worky!!! (bagged89hatch)
checked that too. Its refferred to as G101 in the shop manual. I am pretty sure thats the only ground on the wire harness. please keep the suggestions comming. Thanks a million.
Old Jun 25, 2003 | 12:12 PM
B18C2's Avatar
did u chack your starter, if your starter is bad then your car would not start
Old Jun 25, 2003 | 12:24 PM
lcaruca97's Avatar
Default Re: (E-SiR)
the car turns over, just no spark.
Old Jun 28, 2003 | 08:10 PM
GoodGasMileage's Avatar
Default Re: (lcaruca97)
any update? im interested in finding out what the problem is/was.
