Engine mount difference between DC2 & Ek? (B-series)
Old Dec 4, 2003 | 05:40 AM
SilverEk3dr's Avatar
Default Engine mount difference between DC2 & Ek? (B-series)
If you had a b series swap from a dc2. What mounts would you need to make it work in an EK? I know that the driver side is totally different, but is that the only one? Can you use the others?
Thanks
Old Dec 4, 2003 | 07:12 AM
ddong2lee's Avatar
Default Re: Engine mount difference between DC2 & Ek? (SilverEk3dr)
u need si mount brackets for the rear tranny and front driver's side motor for any b-series into ek.
Old Dec 4, 2003 | 12:51 PM
Default Re: Engine mount difference between DC2 & Ek? (ddong2lee)
Yeah but some of the mounts from the dc2 must be usable. I'm not gonna go buy 3-400 in oem mounts
Old Dec 5, 2003 | 04:50 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but some of the mounts from the dc2 must be usable.</TD></TR></TABLE>
You MUST use a 99-00 Si driver's side mount bracket then you can retain the stock EK mount. The same with the rear bracket - 99-00 Si bracket and reuse the stock EK mount. You can reuse the stock EK upper tranny mount. For the lower front tranny mount bracket you can use the DC2 then retain the EK rubber mount. Same applies to the A/C bracket if you are only using it as a dampening mount - DC2 A/C bracket with EK rubber mount. If you want to have A/C, you'll need a Del Sol VTEC A/C bracket and then use the stock D series compressor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm not gonna go buy 3-400 in oem mounts </TD></TR></TABLE>
It won't cost near that much, but without them you won't be mounting the motor in.
Old Dec 5, 2003 | 05:03 AM
Default Re: Engine mount difference between DC2 & Ek? (VTECVillain)
thanks mayne
Tom123456
Jan 19, 2007 02:15 PM
dc2drifterx
May 9, 2005 12:15 PM
92eg6
May 29, 2004 08:23 AM
black-hatch
Apr 21, 2003 09:08 AM
DevinW
64
Nov 30, 2002 03:12 PM
