engine codes
Old Oct 15, 2002 | 09:22 AM
kuelerz's Avatar
Default engine codes
okay i finally checked the codes on my car and i only have three codes:
Code 4:Crankshaft position senser
Code 7:Throttle position
Code 41: o2 senser
well amazingly when i hooked up the o2 senser 41 went away. the crankshaft senser i dont think is even hooked up becuase i didn't think obd 1 engines had that senser. will i hurt the engine if i drive it down to the muffler shop without it? also were is the senser located, i know is down near the crackshaft pully but is it hard to get to?
the throttle position senser is really screwing me up though. my buddy said i needed to go have it adjusted with an ome meter. is this true? if so could someone tell me how to adjustit, i have an ome meter but i do not know how to adjust it. again will this hurt the car if i drive it?
i have to drive the car to amuffler shop to have my test pipe made, it is going to be loud as hell, open header haha. gotta do it though.
thanks for the help
Old Oct 15, 2002 | 10:09 AM
satan_srv's Avatar
Default Re: engine codes (kuelerz)
Isn't the CKP sensor in the distributor?
Old Oct 15, 2002 | 10:41 AM
kuelerz's Avatar
Default Re: engine codes (satan_srv)
if it is that might explain why my tack isn't working
Old Oct 15, 2002 | 10:42 AM
EP3_05's Avatar
Yep the ckp sensor is indeed in the distirbutor.
Old Oct 15, 2002 | 11:15 AM
kuelerz's Avatar
Default Re: engine codes (91civic)
how do i check it or what do i do to fix it, wires?
Old Oct 15, 2002 | 01:26 PM
kuelerz's Avatar
Prudz_lude
Mar 14, 2008 04:24 AM
shabam
Sep 13, 2007 01:43 PM
NaCk3m
Apr 9, 2007 10:11 AM
bumpin_bass
Dec 30, 2002 05:53 PM
kuelerz
Oct 16, 2002 01:30 PM
