Gsr throttle cable in EK
Old 01-14-2010, 06:48 PM
BucCivicSi99's Avatar
Default Gsr throttle cable in EK
did gsr swap into EK using GSR throttle body and cable can anyone explain or show the right way to use a gsr throttle cable in an EK? it looks like theres too much slack in the cable do i cut it and weld them back together its like 5inch slack
Old 01-15-2010, 07:06 AM
kulo's Avatar
Default Re: Gsr throttle cable in EK
u need gsr tb cable bracket too
it will point upwards rubbing/hitting the hood
i swapped tb to a b16, with b16 cable and bracket
much cleaner
Old 01-15-2010, 08:02 AM
lee97ex's Avatar
im sure this isn't the proper way to do it but, i bought some spacers from lowes and some extended bolts, and that fixed the problem...i can get a pic of it later today if you want to see what im talking about
Old 01-15-2010, 09:00 AM
yea please that will help me alot.,
Old 01-15-2010, 09:12 AM
NOOdS's Avatar
i just used original bracket for my cable and remounted it on the firewall. right above manifold (left prethreaded hole), works pretty good. no rub or anything. you dont have to switch throttle body to b16.
Old 01-15-2010, 09:27 AM
much cleaner
here some pic if you dont know wut im talking about: on the first pic gsr bracket, tb cable and TB
on the 2nd pic i used the 2nd hole to lift it highter and on the last picture on the gas pedal there like 4-5inch slack
Old 01-15-2010, 11:52 AM
ekx4's Avatar
make a bracket that raises that bracket and bolt it all together.
you could also just raise the bracket and use only one bolt to hold the throttle cable bracket together.
Old 01-15-2010, 07:05 PM
do u got some picture that will give me some ideal?? cannot i use civic throttle cable?? or its to short
Old 01-16-2010, 04:23 AM
ekx4's Avatar
you would need a gsr throttle cable. its basically like this you would want to make a bracket so that your throttle cable bracket now (gsr one) will be able to bolt onto your ghetto rigged bracket then bolt the bracket down on the throttlebody
Old 01-18-2010, 03:45 PM
well, this the best i could do hey its work thank
Old 01-19-2010, 07:36 AM
ekx4's Avatar
lol
Old 01-19-2010, 07:37 AM
ekx4's Avatar
are you using a ek throttle cable?
Old 01-19-2010, 07:53 AM
B16acivicsedan91's Avatar
Thats odd, My car has the stock teg tb and intake mani and stock bracket with a gsr cable and it fit like a glove. Its a 97 coupe.
Old 01-19-2010, 09:17 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Oh, I know what you're talking about, I think... you're saying there's slop in the pedal, right?
I used a couple of zipties behind the pedal to take up some of the extra cable. Just wrapped them around the cable.
But then again, yours looks like it has a TON of play in it, which I don't understand. I'm running gsr manifold, throttle body, brackets, and cable in my EK and it fits fine more or less.
Are you sure the cable's not broken in the middle somewhere?
Old 01-21-2010, 10:59 AM
ekx4's Avatar
i think he has the wrong cable.
Old 01-21-2010, 11:46 AM
NOOdS's Avatar
lol, somethings not right about your cable. its super long.
Old 01-21-2010, 12:54 PM
freshvibes's Avatar
Yeah dude you need to get a gsr cable and the bracket that bolts onto the firewall.
Old 01-30-2010, 09:57 PM
i order the thorttle cable for Acura dealer they cannt give me the worng thorttle cable cuz it say p72 17910-ST7-A81 on it that was i try to tell y'all its to long
Old 01-30-2010, 10:20 PM
but it work the way i had it
Old 04-17-2011, 05:48 PM
98mugenferio's Avatar
hate to bring up a VERY old thread but I just wanted to add something to this since it served helpful to me I know it will serve helpful to anyone else who uses the search function. I haven't found anyone else who has ghetto-fabbed a bracket like ^ which is kinda why I'm reviving it.
I have the exact same problem as the OP and the long *** throttle cable he is using looks like the one I am using now in my CX. The throttle cable on the EX/HX/SI is the same (from what I have found) and the CX/DX/LX is different because the throttle body is mounted vertically instead of horizontally like in the ex/hx/si/ls.
To the OP, do you still have this set up? where there any problems with it? have you changed it at all?
Old 03-19-2012, 07:57 AM
NOSPNSRS's Avatar
I'm having the same problem, I read on the forums to use a EM1 throttle cable and I have a lot of slack underneath by the pedal. I used zipties and washers to take up the slack, but I want something reliable that is sturdy and works! Does anyone have a pic of how a stock gsr cable is routed? Thanks!
Old 03-19-2012, 02:33 PM
I used a P75 throttle cable bracket a M6x1.00 bolt and some creativity. (this is for an LS swap)
I forgot about this thread. I figured out how to make it happen cap'n. You route the throttle cable through the bracket that holds the hose from the brake master to the IM. The trick is though, you have to use the holders on the bottom.
Then you loop it around the shock tower and you can either run it under a strut bar (if you have one) or run it through an open space in the plastic thing that holds the washer hose.
Then you run it to the throttle body (using an EK throttle wheel on a GSR TB) adjust out the slack and you have a fully functioning throttle cable with no money out of pocket and stone reliable.
import-tooner
01-25-2011 05:30 AM
mardoiii
11-02-2008 08:23 PM
gapergurlie_18
10-23-2008 05:22 PM
Phatch99
10
06-18-2004 12:56 PM
Benny Z
06-30-2003 07:00 PM
Quick Reply: Gsr throttle cable in EK
