Eg swap help
Hi
I have a 92Vx hatch and i recently put in a b16 (sir II) and i did the rewiring of the o2 down to 4 wire with no CEL. I added the knock sensor wire no CEL.
When I start the motor it runs good but CEL is on code 3 and 7 Map and TPS
I have swapped the plugs reset ECU (dc the neg term on batt) same CEL's
One Plug RGY wires and the other is RGW
I have two other Map sensors (and the stock one VX one) i got both of them off EBAY one said it was for a b16(it mounts on the TB) and the other said it was from a d15(mounts on fire wall)
the b16 motor i got does not have the map Mounted on the TB (like my stock)
When I rev the motor its good (Little slow) Idle to ~3000 over 3k it bogs when I get it to rev higher ~7k down when i give gas well Idling down it bog
So what plug goes to witch sensor goes to what plug one with yellow wire or one with white wire
And any other ides on what it might be?
oh also I am using the stock VX harness and a JDM p30 ECU
Mike banX
Dec 6, 2010 03:35 PM
