eg hatch hasport mount problem
ok so i bought a 92 eg hatch with an h22a swapped into it with hasport mounts and axles. driving it home i noticed a vibration during slower speeds and under full throttle. when i got it home, i was looking in the engine bay and noticed that the side motor mount bushings nearest the firewall were squished, and on the side closest to the front that there was space between them. then i noticed the bad angle the axles had, which i'm assuming is why it vibrates
. so my question is is this a normal problem with the hasport mounts and how could it be fixed??? i know that with an h22 swap, there is usually an angle in the axles, but i think the mounting problem is making it much worse. i was thinking to space the rear mount up somehow to tilt the engine/trans forward more? i'll try to get better pictures up soon, any help is greatly appreciated!
drivers side
passenger's side
passenger side from a different view
. so my question is is this a normal problem with the hasport mounts and how could it be fixed??? i know that with an h22 swap, there is usually an angle in the axles, but i think the mounting problem is making it much worse. i was thinking to space the rear mount up somehow to tilt the engine/trans forward more? i'll try to get better pictures up soon, any help is greatly appreciated!drivers side
passenger's side
i was also thinking that maybe it has the 62a bushings which are the softest ones and they just wore out over time. the guy i bought it from said he did the swap in 09, so maybe it just beat up the bushings and with new ones it would sit fine? idk... and when i get new bushings should they be 62a or 70a?
i would get the 62's but i wouldn't want to have to replace them later on because they got chewed up like these ones so i might get the 70's where they're harder so maybe they'll last longer
yea i'll probably go with the 62a cause its going to be my new daily and i'll probably just buy some new ones and install them myselfsince they're only about 7 bucks
jellybeanracer
11
Dec 22, 2012 02:29 PM
Turbo-Tec
21
Jun 17, 2005 06:31 PM
