EG H22 Swap Code 6
Old Feb 22, 2019 | 02:24 PM
MastaFlyMason's Avatar
Default EG H22 Swap Code 6
So I have a 94 Honda Civic with an H22a4 swap and I'm getting a code 6 which is for coolant temp sensor and I'm guessing why I'm having cold start issues. I have 3 connectors which I believe are all coolant temp but only 2 on the wiring harness (I didn't swap this car myself)
Which goes to what? I've tried all configurations and still have the CEL so I'm thinking maybe a sensor or wiring is also bad. Anyone have a good idea on where to go from here?
Both wires are 2 pin one is black and green wiring the other is red and green.
Old Feb 22, 2019 | 10:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: EG H22 Swap Code 6
The grey plug with the black and green wires is the fan control switch. The sensor pictured in your top pic on the upper radiator hose port/fitting is the secondary fan control switch... which is not needed in your application. The ECT sensor is the one you have in the second photo... and the correct plug for this sensor is the grey plug with the red/white and green/white (although the trace could be blue or black). The green/white wire would have continuity to ground and the red/white wire would have continuity to D13 at the ECU. If these two wires test good... replace the sensor.
Old Feb 23, 2019 | 07:11 AM
**** yeah, that got me up and running. Was having issues on cold starts and vtec not engaging everything works great now. Much appreciated man, I owe you!!
Old Feb 23, 2019 | 10:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You don't owe me... I am always happy to help... especially when it comes to a fellow "H" swapped EG owner. I have had one since 2002 and I LOVE it.
Nathan_volcom
Dec 4, 2011 03:01 PM
chas92h22
Dec 31, 2007 05:20 PM
Hcivic88
17
Apr 27, 2004 09:23 PM
89a6T
Apr 4, 2004 08:28 AM
BIG RICH
Oct 16, 2002 10:17 PM
