ecu question
just got the right ecu from HMO, and ive hooked it up but it turns on the engine light when i hit vtec...but it doesnt throw codes when the car is on..any ideas on what the problem could be? thanks.
hmmm.
Have you tryed uhhh...
CHECKING THE CODE???
If the check engine light is coming on then it should store the code in memory.
Should I highlight that for you?
The ecu stores the code once the cel comes on.The cel doesn't have to be on in order to pull a code.So pull the code and find the answer......easy as 1-2-3
please check the codes first on the ecu and get back to us with something more tangiable.
thanks to katman again
[Modified by eg6ajk, 9:29 PM 12/30/2002]
efcivic2dr
Apr 1, 2008 09:20 PM
crxaddikt
Dec 1, 2003 09:23 AM
BigMig
May 10, 2003 06:01 PM
