ECU Code
Old Oct 2, 2002 | 07:23 PM
td04civic's Avatar
Default ECU Code
I just wanted to know what is the code for a 93 h22a1 motor. My cousin has it in his car. The ecu say p13. But it redlines at 6500. Isn't it supposed to be 7500?
Thanks
Old Oct 2, 2002 | 07:26 PM
prelude1897's Avatar
Default Re: ECU Code (td04civic)
First find out what code its throwing....See how many times the check engine light flashes, and thats how you get your code
Old Oct 2, 2002 | 07:28 PM
td04civic's Avatar
Default Re: ECU Code (prelude1897)
sorry i worded my question wrong. I meant what is the name of the h22 ecu. Is it p13?
Old Oct 2, 2002 | 07:43 PM
yeah...
Old Oct 2, 2002 | 09:40 PM
Jago's Avatar
You probably have a US spec ECU if it redlines at 68 thousand
My JDM h22 does the same thing, I'm just gonna chip the ECU.
Old Oct 3, 2002 | 04:15 PM
td04civic's Avatar
Default Re: ECU Code (Jago)
I have another problem w/ the car. The check engine light is on and when i try to jump the code from the ecu the light just stays on without flashing. What could cause this problem?
And is 6800 the redline on us spec h22's? i thought it was 7500..let me know what you think.
Thanks for the replys.
Old Oct 3, 2002 | 08:48 PM
Are you sure you're jumping it right? you should be redlining at 7500 rpms
Old Oct 4, 2002 | 01:24 AM
Acclude's Avatar
hav u fixed ur problem wit the redline yet??because ive gat the same prob just wonderring how 2 fix
Old Oct 4, 2002 | 06:07 PM
td04civic's Avatar
Default Re: ECU Code (Acclude)
no i did not fix the problem yet. It's my friend's car and he told me he's not feeling vtec. How do you check the solonoid since the ecu is not letting me jump the codes?
Old Oct 4, 2002 | 10:00 PM
EH2DX's Avatar
no, the redline is not 6500. the ECU limits your revs to 6500RPM because there is something wrong. any time you have a check engine light, the ECU will do this as a safety feature. not all codes though. but yeah, as soon as you fix the problem and reset the ECU it will go back to normal.
bigislandc2
Aug 31, 2006 09:15 PM
MelloYelloCRX
Jul 22, 2006 05:17 PM
civic_sir94
Dec 30, 2002 09:23 PM
ang
Nov 27, 2001 09:38 PM
