ecu pin problem
Old 10-02-2003, 05:08 PM
ZaxEG's Avatar
Default ecu pin problem
whats up?? I swapped a b16 in a 94 vx and wheni went to wire uot he knock sensor there was a wire already in D3 i think it blue and green. What the hell isn't that space for the knock sensor. should i just slpice it to the wire or what? thanx
Old 10-02-2003, 06:41 PM
JV
Who?
JV's Avatar
Default Re: ecu pin problem (ZaxEG)
If it's a Blue/Yellow wire then it ran to the 5 wire O2 sensor that only the VX model had.
D3 will not be used with a 4 wire O2 sensor, so you can de-pin/re-pin or cut and splice for the knock sensor.
Old 10-02-2003, 07:35 PM
VTECVillain's Avatar
The wire at D3 went to the original wideband O2 that the VX used. It is a shielded wire and can be used for the knock sensor. One simple change at the shock tower assuming that you are using an engine harness that has the knock sensor embedded makes wiring it very simple.
juanchoenuncrx
08-24-2007 04:48 AM
nub_pwn
11-18-2006 11:48 PM
stillrockin18s
07-21-2005 12:13 AM
Quick Reply: ecu pin problem
