Ect sensor problem
Old May 25, 2004 | 02:38 PM
IHateJDM's Avatar
Default Ect sensor problem
I just finished a jdm h22 swap into a 93 del sol, and my ecu is throwing a ect code (6). Does anyone know what the pinout on the ecu is for the ect. I'm running a chipped obd1 p28. I just wanted to make sure it is wired right before I go out and buy the sensor, this swap drained my wallet.
Old May 25, 2004 | 02:45 PM
Turbogixxer's Avatar
Default Re: Ect sensor problem (93delslo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93delslo &raquo;</TD></TR><TR><TD CLASS="quote">I just finished a jdm h22 swap into a 93 del sol, and my ecu is throwing a ect code (6). Does anyone know what the pinout on the ecu is for the ect. I'm running a chipped obd1 p28. I just wanted to make sure it is wired right before I go out and buy the sensor, this swap drained my wallet.</TD></TR></TABLE>
You talking about the ECT sensor on the head (under the dizzy) or the ECT sensor on the thermostat housing?
If it is the one on the head:
RED/WHT - D13 (signal)
GRN/WHT - D22 (sensor ground)
Old May 25, 2004 | 02:58 PM
IHateJDM's Avatar
Default Re: Ect sensor problem (turbogixxer)
yes, it was the one on the head, and yes i had it mixed up with the vtec clip (which i hard wired since my car did not have it), and my cel is gone. Thank you very much, i've been in limp mode for 3 days and it's been killing me.
jenishereto
Mar 7, 2014 04:16 AM
scerbz
17
May 13, 2013 08:39 AM
JDM_EK4_Coupe
Apr 30, 2007 11:43 AM
mslate
Jul 26, 2006 04:57 AM
racingant
Sep 10, 2005 05:34 PM
