Drivers side axle popping out.
My cv axle is popping out of intermediate shaft. I have had 2 new axles and they both did it. I have a 94 accord with a h22w/tranny in it. I used the accord axles with accord intermediate shaft like u are supposed to. I have had no prolblems with my passenger side. But for some reason my driver side always want to pull out of the shaft. What could cause this to just pop out like that. I have reccently raised my car to stock and it still does it.
Have you tried expanding the snap ring so it sets in the differential? That might be your problem. Try expanding it a tad and make sure it clicks when it sets itself in the diff. Good luck.
Are these newly remanufactured axles? I have came across a few that after being rebuilt they ended up being shorter than spec. Cutting a sharp turn would make it pull out from the tranny side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEANB18 »</TD></TR><TR><TD CLASS="quote">
And you're positive the axles 'snapped' into place in the tranny? </TD></TR></TABLE>
believe me, if they didn't snap into place, you'd be able to hear it the moment you start the car.
Not necessarily. This happened to me last year after being forced to replace an axle at the drag strip. I thought I had it completely in place, it felt like it had "snapped" in place, but It sure didn't. (sorry, I'm sure snapping into place isn't a technical term, but its the best way I can describe it.)
Didn't sound any different when i started the car. after backing out, I put the car into first gear, let out the clutch, and started rolling when the axle popped out.
So it made it the first few feet backing up just fine, and made it a few feet in a forward gear then popped out... without any change in noise.
But it doesn't sound like it's this guy's problem either though
No it is popped in and doesnt move. I think it pops out after cornering. It seems to be a problem of getting pulled out bc it is too short. Someone said in a post to cut the boot ring bc maybe the air suction in there is pulling it out.
I know this is an old thread, but does anyone have any updated info on this problem? My car's doing the same thing. '94 Accord EX 2.2L 5spd. Can't figure it out and having trouble finding threads with definite answers.
Accord94DX
May 14, 2002 02:02 PM
