G23 help and s2000 crank into a f23a1
Old 01-29-2017, 08:23 AM
Newbyhonda's Avatar
Default G23 help and s2000 crank into a f23a1
Ok so here it is, I'm building a 93 del sol. It has a d16z6 that I've already pulled turns out the head is completely destroyed. So I've done some research and i already have a h22 block that a rod has gone through and a low mileage f23a1. I was wondering is its possible to put a s2000 crank into the f23 and if you're able to what mods do you have to do and also i know you have to bore the f23 to 87 if i remember right to match with with the h22 head bore i just need ideas and help
Old 03-12-2017, 09:52 AM
Talon9871's Avatar
Default Re: G23 help and s2000 crank into a f23a1
I highly doubt that either the 84mm stroke F20C crank or the 90.7mm stroke F22C crank will work in the F23 block, since those engines are so different from the rest of the H/F series. I'm not really sure what that gains you anyway - if you're trying to build a de-stroked F23 block, you might as well just skip the complicated hybrid setup and put your time and resources into fixing/replacing your H22 block.
If you decide to pursue the H22/F23 hybrid, you have a lot more homework ahead of you. Before you go any further though, here are a few things to consider:
  • Using the F23 block limits you to using the F23 crank and F23-compatible rods (You may also be able to use F20B internals, but you'll need to do the homework). Note that stock F23 rods may not be safe to rev past 7000rpm, and there are very few aftermarket options.
  • The F23 block doesn't HAVE to be bored out to 87mm (mine isn't), but either way, you'll have to figure out what to do about pistons. At 86mm, you could use the F23 pistons (giving you low compression, not recommended for N/A builds) or K20A2 pistons (giving you fairly high compression, not recommended if you want to boost it). If you bore to 87mm, you'll probably have to use custom-made pistons, as there may not be any ready-made 87mm pistons that fit on F23 rods.
  • You'll have to use a standalone EMS, and either learn to tune the car yourself, or pay someone else to do it.
I've done this build myself (H22A1 head, K20A2 pistons, F23A1 block), and I don't recommend trying it unless you REALLY want the experience. In my opinion, this isn't a particularly cost-effective or reliable project to tackle.
Navy_CRX
07-06-2010 02:25 PM
fukenricen
12-25-2009 03:37 AM
SiR-T
04-06-2008 07:26 PM
Quick Reply: G23 help and s2000 crank into a f23a1
