Downsides of an H22.
Old Feb 8, 2003 | 10:49 PM
  #26
Jonathan_ED3's Avatar
Default Re: Downsides of an H22. (cccya)
i only get 250 per tank. soon to come. injector resetor box, and B&M FPR w/ gauge. that should help feul econmy
does not having it wired up in some way affect fuel economy?
Old Feb 9, 2003 | 06:02 AM
  #27
VTECVillain's Avatar
Default Re: Downsides of an H22. (redlineh22a)
Better change that avatar to bottomed out H22A inside if you plan on using 2.3" drop springs!!! I would take the suspension just as seriously as you will the swap.
Old Feb 9, 2003 | 08:09 AM
  #28
GsR HtCh's Avatar
Default Re: Downsides of an H22. (VTECVillain)
bump for h22 powwa
Old Feb 9, 2003 | 12:18 PM
  #29
Braco11's Avatar
Default Re: Downsides of an H22. (paybac4223)
You are also gonna need heaver springs to hold your front end up...
Will integra springs work on an eg??
Old Feb 9, 2003 | 12:23 PM
  #30
redlineh22a's Avatar
Default Re: Downsides of an H22. (Braco11)
Like I said, I probably will not get these 2.3" springs but, what other ones are good to use and will they take a new camber kit?
Old Feb 9, 2003 | 04:31 PM
  #31
JDMH22HATCH's Avatar
I've never hit my header or oilpan. I'm not sure how much my drop is since they're coilovers, but since my suspensions so stiff that I don't have a problem with hitting bottom. Plus roads down here are pretty nice as well so I guess that helps out.
Old Feb 10, 2003 | 06:00 AM
  #32
GsR HtCh's Avatar
Default Re: Downsides of an H22. (JDMH22HATCH)
i got another ? how hard is it to keep power steering and ac when you swap the h22 in. i would want both because its gonna be a daily driven car until i can get another one. thanks
Old Feb 10, 2003 | 07:59 AM
  #33
The G2 Racer's Avatar
Default Re: Downsides of an H22. (98civichtchback)
I believe their is someone here on HT that makes a bracket to keep power steering.
I'm thinking about this swap myself but I've been told h22s burn oil and aren't good for turbo set up, this true?
Old Feb 10, 2003 | 08:54 AM
  #34
sdadlani's Avatar
Default Re: Downsides of an H22. (The G2 Racer)
My local tuner shop charges 800 for a B series swap, how much am I lookin at for the H?
Thanks!
Old Feb 11, 2003 | 06:03 AM
  #35
Drews Bitch's Avatar
Old Feb 11, 2003 | 08:41 AM
  #36
H22EK's Avatar
Default Re: Downsides of an H22. (sdadlani)
Thanks!
Man do it yourself, it is not that hard and there are enough posts on here that oyu should be able to do it no problem! Hit me up if you have any questions, also Poison is a very good reference!
Old Feb 11, 2003 | 09:28 AM
  #37
thinkbrianthink's Avatar
Default Re: Downsides of an H22. (EK22Tim)
How big is the EK hatch gastank?
Ive run my car till it sputtered and then filled the tank. 10.5 gallons.
Old Feb 11, 2003 | 09:52 AM
  #38
EKhothatch's Avatar
Default Re: Downsides of an H22. (thinkbrianthink v.1)
When I had my 2000 civic HB the fuel tank held 11.9 gallons. I was always running it extremely low.
Old Feb 11, 2003 | 09:53 AM
  #39
Default Re: Downsides of an H22. (inline4hatch)
Wanna fight?
Old Feb 11, 2003 | 09:56 AM
  #40
EKhothatch's Avatar
wanna bigger gas tank?
Old Feb 11, 2003 | 11:18 AM
  #41
GsR HtCh's Avatar
mine holds like 12-13 gallons. BTW how much boost can a stock h22 handle without hurting it??
Old Feb 11, 2003 | 11:40 AM
  #42
hrmmm maybe i got stiffed.
or maybe it was a drug repo and they just told me it was new.
*goes to check tank for drugs*
Old Feb 11, 2003 | 11:44 AM
  #43
EKhothatch's Avatar
haha possibly, mine was drug repo free i'd have that checked out
Old Feb 11, 2003 | 12:08 PM
  #44
GsR HtCh's Avatar
what model do you have. did the different models come with different size tanks or did you just get a crazy small one
Old Feb 11, 2003 | 12:22 PM
  #45
4g4me's Avatar
TRy this.....
https://honda-tech.com/zerothread?id=409461
I dunno if some of you read the eg+civic forum, but this is a link to my experience. I believe that mere intimidation scares people away from this swap........well you read.
H22a powered civic gets a from me
Old Feb 11, 2003 | 12:27 PM
  #46
EKhothatch's Avatar
I believe the 6th gen civic's have 11.9 gal and 5th gen vx and cx models had 10.0 gal tanks.
Old Feb 11, 2003 | 08:08 PM
  #47
StorminMatt's Avatar
The biggest downside is the fact that there is no kit available for swaps into 1988-1991 cars. If this is what you are swapping into, you MUST cut and weld.
Old Feb 12, 2003 | 04:53 AM
  #48
BeerBaron105's Avatar
Default Re: Downsides of an H22. (StorminMatt)
plus efs have the worst weight distribution
and an h22 can hold psi just like any other motor
7 with a crap fmu, and over that with hondata and what not
its all a myth (this motor cant hold boost blah blah)
i see d-series holding 10-12 psi with good fuel management
Old Feb 12, 2003 | 02:17 PM
  #49
Nebula's Avatar
New User
Default Re: Downsides of an H22. (BeerBaron105)
How about when you have to change the alternator belt isn't that going to cause some problems?
Old Feb 13, 2003 | 04:29 AM
  #50
EK22Tim's Avatar
Default Re: Downsides of an H22. (Nebula)
I have not had probs with the alternator belt at all.. I have had it off probably 5-6 times since the install. Not really an issue.
