Distrubitor INterchangerable?
Old Jul 16, 2002 | 07:48 PM
CRAYZBOYZS's Avatar
Default Distrubitor INterchangerable?
Just wondering if a dist from a 99 obd2 civic dx can swap onto a 92 jdm obd1 engine thanks
Old Jul 17, 2002 | 09:36 AM
Katman's Avatar
Default Re: Distrubitor INterchangerable? (CRAYZBOYZS)
well is the 92 engine a SOHC also? if so, yes it will work on it, but you'll need to either rewire the 92 vehicle to use an OBD2 distriutor or you need to run a 96-00 integra engine harness, which will work on a 92 Honda civic/integra vehicle.
Old Jul 17, 2002 | 02:57 PM
CRAYZBOYZS's Avatar
Default Re: Distrubitor INterchangerable? (Katman)
ok heres the deal the 92 jdm engine is a b16a. I'm using my stock 99 civic dx harness and added the vtec and oil pressure iac etc and rewired the alt wires to obd1. The only problem I have left is the dist. I can't figure out how to rewire my harness obd2b connector to the obd1 dist. my harness dist has 8 wires and the 92 jdm dist has 9 wires... any help would be appreciated thanks
Old Jul 18, 2002 | 01:02 AM
Katman's Avatar
hmm, well i hate wiring. If I were you I'd just find a 96-01 B-series VTEC distributor and call it a day. It will plug n' play onto your DX harness.
CarFreek
Jun 5, 2012 06:31 PM
shadyCTR
Apr 1, 2008 12:45 PM
93(Civic)EG6
Jul 15, 2007 12:52 PM
TodaSi
May 19, 2002 04:32 AM
CanuckCRX
Nov 22, 2001 11:43 PM
