difference between 90-93 teg linkage and 94-01 teg linkage...EG swap concerns
Old 11-08-2006, 10:57 AM
at the jetties fishin'
stackz's Avatar
Default difference between 90-93 teg linkage and 94-01 teg linkage...EG swap concerns
I have the linkage from the donor 91 teg for my eg hatch install but my friend is saying it will require modification to work correctly.
whats different between the 90-93 linkage and the 94-01 linkage that makes the 94-01 linkage the one you need?
I cant use the 90-93 linkage at all?? if I can, what are the modifications that I need to do??
I was under the impression that it would bolt in just fine but that my shifter would be a little farther forward in the console....
Old 11-09-2006, 06:22 AM
JasonST's Avatar
Default Re: difference between 90-93 teg linkage and 94-01 teg linkage...EG swap concerns (stackz)
What kinda swap u doing? I think that one of them is a tad bit longer than the other one, though I don't remember which one.
Old 11-09-2006, 06:44 AM
stackz's Avatar
Default Re: difference between 90-93 teg linkage and 94-01 teg linkage...EG swap concerns (JasonST)
putting a b18a and cable tranny from a 91 teg into my 93 civic hatch.
shortA25
10
10-24-2010 07:00 PM
Clipsed
01-20-2009 11:51 AM
stackz
01-04-2007 11:20 AM
Jared
01-28-2002 07:02 PM
Quick Reply: difference between 90-93 teg linkage and 94-01 teg linkage...EG swap concerns
