dented oil pan
Old Sep 25, 2002 | 08:55 AM
jdmcx's Avatar
Default dented oil pan
hey i just got my motor and the oil pan is dented what kind of problems would i get it is not dented badly but enought to make me fell bad
thnks for your help
Old Sep 25, 2002 | 09:46 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: dented oil pan (jdmcx)
as long as its not creased, and just a little ping, u should be fairly safe, .. where is the dent, in the middle or on one of the sides or bends..
Old Sep 26, 2002 | 07:27 AM
jdmcx's Avatar
Default Re: dented oil pan (SIXTYdashONE)
in the middle of te pan
i guess from shipping
Old Sep 27, 2002 | 04:01 PM
HT's Biggest Loser
well if its in the middle, it shouldnt be to bad as long as its not hitting antyhing inside, if its to the point to where its creased, u may want to fix it, other then that if its just a surface indent or ding, u should be fine.
Old Sep 27, 2002 | 05:09 PM
Kamin's Avatar
POUND IT OUT
i repeat
P O U N D I T O U T!!!
mine was dented and caused my vtec not to work.
the oil pickup is in the middle of the pan. my oilpan was HITTING the pickup. i have pictures where it scratched the bottom of the pan.
Old Sep 28, 2002 | 06:28 AM
Monty's Avatar
Default Re: dented oil pan (KAMiN)
I second that you shoukld definately check the pickup. My pan was dented also. Heres what the pick up looked like
http://www.norcalcrx.org/monty/bent%20pickup.jpg
Kind of big pic, hope it helps.
Monty
1991 CRX SI
1991 B16 J1
almost to v-tec
Old Sep 28, 2002 | 06:45 PM
bluesaint's Avatar
Default Re: dented oil pan (Monty)
i had a dented oil pan and it caused oil starvation which led to flat spotted ITR cams
Old Sep 29, 2002 | 02:00 PM
MPower332TI's Avatar
Default Re: dented oil pan (bluesaint)
mine was dented when i got it..i took off the pan to check the pick up and it was fine...so to be save we took a big hammer and a block of wood and hammered that **** out...good luck
Old Sep 29, 2002 | 04:39 PM
AzN_Flava's Avatar
Default Re: dented oil pan (jDmDxTuRd)
what motor is the oil pan from? i may have an oil pan for sale...
Old Sep 29, 2002 | 08:31 PM
irev210's Avatar
i have stock b16 oil pans with no dents in them
60 bux ship'd
if u dented ur oil pickup i got those also
20 bux
Old Sep 30, 2002 | 08:20 AM
jdmcx's Avatar
Default Re: dented oil pan (AzN_Flava)
i is on an ls vtec so it would be a b18a bottom end
thanks
Doctor CorteZ
71
Dec 16, 2005 08:30 PM
Cyber ITR
Jan 6, 2005 10:17 AM
fastest
May 19, 2004 08:20 PM
Adam.C
Apr 5, 2004 04:41 PM
civickiller
May 17, 2003 08:35 AM
